Hi guys, im from NZ and though that i would post my ride on here to show you aussie guys my car since there is little to no stanzas in NZ and i like to see more of them tastefully modified.
So here mine is, its a 79 model A10 Stanza SSS, shes been panelled and repainted in fords hue of chilli orange and the bumpers and rear light surrounds are painted in mitsubishi outlander door handle grey.
the wheels are SSR longchamps measuring 14x6.5 and 14x7.5 front and rear respectively.
the engine is the factory L16 engine with rebuilt bottom end to factory spec then the head is a W53 with 2mm oversized valves and 3 angle valve grind, 40 thou skimmed, stage 3 cam grind (230 degrees duration at .050) and uprated valve springs from Franklin Camshafts NZ, twin dellorto manifold (portmatched) with twin 40mm dellorto carbs, 4-1 headers and full 2 inch exhaust system, MSD CDI ignition system with programmable rev limiter, tuned by myself then run on a dyno to check readings was making around 85-90 hp at the wheels and has run a 16.78 @ 80mph on the strip.
here are some pictures, hope you guys like it.
Attachments: |
