Hey guys here is a couple pics and specs on my 1980 1200 ute.
Engine: CA18DET, CP forged pistons, tomei 272 cam shaft, tomei cam gears, garret GTX30/76 (22psi), haltec E8, 660cc injectors, custom plenum.
Drivetrain: S13 gearbox with BnM short shifter, Exedy twin plate brass button clutch, R31 Skyline diff with mini spool.
Brakes and suspention: S13 slotted disc brakes all round, S13 struts up front, Standard leaf springs in rear.
Wheels: Front: 16 slot skyline rim (15 X 6.5), Rear: Simmons FR (16 X 7.5) with kumho semi slick
Body work: welded tail gate, mini tubbed (chassis not yet modified), shaved vents
____________________________________________________________________________________________________
At the moment i am re-buliding the motor. I am chasing 500+rwhp. The modifications currently happening are as follows;
2.1L stroker kit - JE forged piston, spool forged rods and spool forged crank.
E85 fuel system - 2 X bosch 044 pumps, 1600cc injectos, 54L fuel cell, turbosmart fpr 800 fuel reg.
PWR water to air cooling system
Garrett GTX30/76 with 0.85 rear housing.
Attachments: |
