It is currently Tue Jun 18, 2024 10:50 am
 Post subject: irs 200b diff options
PostPosted: Sun May 05, 2013 12:40 am
are there any bolt in upgrades after a D bomb that left my diff use less its irs cheers guys.
PostPosted: Sun May 05, 2013 10:42 am
Hey mate, I'm upgrading the diff in my 1600 to an r180 LSD out of a subi wrx sti. This is an overkill for my car as I'm only running a worked l18 but the old r160 died under the pressure.
Another option for you is too look for an r160 subi LSD, try japos donks in wodonga as their a specialist subi wrecker.
With the subi upgrade you will need to modify the output shafts to suit the datto shafts and a set of 1600 flanged half shafts. There are a few posts in the driveline section on exactly what to do.
If you want any parts for your existing diff to get it going let me know because I have a few diffs in bits and I'm only at wagga. Let me know.
Chris Thomas
1971 1600, mild L18, 5 speed
PostPosted: Sun May 05, 2013 5:14 pm
so 1600 rear ends are the same as 200bs?
PostPosted: Sun May 05, 2013 5:37 pm
The diffs are, the suspension is different tho
Chris Thomas
PostPosted: Tue May 07, 2013 1:42 pm
MR30 skyline hatch cv-jointed R180 rear ends are virtually a bolt in job apparently.
Gives you disk brake, LSD and upgrade to R200 options if you're interested in that
widens track by 30mm or so
you are not a beautifull and unique snowflake...
PostPosted: Tue May 07, 2013 9:04 pm
so a r180 wont just bolt into stock sharfts
PostPosted: Wed May 08, 2013 5:51 pm
you will need the diff stubs from the R180 from memory and these then bolt the std uni joint flanges...
Users browsing this forum: Google Adsense [Bot] and 1 guest
