Hi guys,
Some searching brings up that the early 180b steering box is exchangeable for the late 1600 one with the collapsible column eg:
http://www.ozdat.com/forum/viewtopic.ph ... +box#p9538
Is the 180b pitman arm the same as the 1600 or do you have to swap it over - couldnt find a confirmation nor denial when searching. Baz probably knows off the top of his head
Thanks guys
Pitman arms are the same on both steering boxes.
