Cheers Guys,
The engine will be for a 1600 when I get it, but havent been able to find a decent shell as of yet for the right price. It's not for any particular application just wanted to build this engine to have a bit of balls for a weekender.
I Started it up for the first time last week, ive been building it slowly over the past year. So no numbers yet, when i get it in a car ill get dyno'd. Its still not 100% finished, going to put a new rocker cover on it and braided lines.
Specs are crow cam, 40mm keihin carbs, lightened flywheel, 4-1 extractors, hot spark ignition.
As for the radiator, haven't thought about it, though i won't be using the standard one, ill get ali one and run thermos. I know Silvia's have a real thin radiator so might try that.
