It is currently Wed May 22, 2024 7:46 am
PostPosted: Sun Oct 16, 2011 7:29 pm
Hey,
when i built my engine i forgot to put the spacer on the fuel pump and snapped the pump arm.
I bought a brand new pump and all is fine BUT, wouldn't be scared to put it aside for an electric fuel pump if there is a definite advantage.
So far all i can see if the crank time would reduce due to fuel being pumped before cranking, but is there really any other advantage, esp if I'm not running a surge tank or anything.
I'm thinking not worth it till it dies (if that ever happens)
PostPosted: Sun Oct 16, 2011 9:30 pm
You're right. The mechanical one is fine. Electric pumps are a fair bit of mucking around to do properly and no real advantage on a carby fed street engine.
PostPosted: Sun Oct 16, 2011 10:47 pm
i have a pair of 45 side drafts webs,am i ok with the mechanicle....engine builder says not,but im not sure,im happy either way.
opinions?
i can turn any hexagon into a perfect circle,pass me the multi-grips will you?
PostPosted: Mon Oct 17, 2011 10:00 pm
dats-son wrote:
I have a pair of 45 side drafts webs,am I ok with the mechanicle....engine builder says not,but im not sure,im happy either way.
opinions?
I wouldn't see y not, like i had mentioned the only advantage i could see would be on startup.
The only thing i have done is I went to sprints today to look at changing the 1/4" fuel line to 8mm from the filter to the carbs. Depending on ur pump u might have to change the inlet and outlet on the pump itself. For some reason my filter has an inlet of 8mm and outlet of 1/4" then 1/4" to the pump then out to the webers. Im just going to run an inline filter and run 8mm straight thru to the webers.
Honestly i doubt it will make much, if any, difference but just look a bit cleaner than the braided aero flow sh*t thats there at the moment.
PostPosted: Mon Oct 17, 2011 10:46 pm
The specs for the standard mechanical pump are that it delivers a minimum of 1.6 litres of fuel per minute whe running at 1,000 rpm. I reckon that's plenty :thumbsup:
PostPosted: Mon Oct 17, 2011 10:48 pm
how many psi?
weber says it neeeds between 2-4
PostPosted: Thu Oct 20, 2011 12:48 am
I've seen a 200bhp race L-Series happily running a stock Bluebird mechanical pump. Pretty sure it had no aftermarket fuel pressure regulator, either. Try it, should be fine. Then you can spend your money elsewhere.
Cheers!
Users browsing this forum: Google [Bot] and 1 guest
