Hi Mate.
I was trying to see your car Domain page yesterday, but for some reason I could not enter your page, I could only get as far as your name and small pix of your 180B...
Thanks for your reply. I will check Scott's. I purchased the trunk seal/boot seal from him. At the same time I ordered the door weather stripping/door seals...but what I got was the "sedan 4 door ) seals.
. I have a friend that is fixing up a 4 door, so I was able to sell the seals.
Rare Spares has those parts ( they call it belts.) Check it out in case you end up needing it. They have stores all over AU from what I saw. I will relay their reply once they reply ( if they do.)
How is your 180B doing?? Any updates? Mine will be ready soon, the rainy season is coming and I want it on the road before that, in about 2 weeks.
Cheers.
Jaime._____________________________________________________________________
Hey bro,
Yeah I took it off from there since I never have the time to Update it so I've temporarely removed it till i have it finished.
Yes that can happen offten specially if you don't quote any part numbers and what not, Rare Spares mainly do GM, Ford and the like here since it's their main stream market and are able to sell much more of that kind of stuff.
At the moment it's in bits, well the whole front end is, I'm doing a SR20DE conversion atm and have so far stripped the whole front end, wire brushed it back to bare metal, stitch welded the chassy and have been doing a couple coats of etch primer and will hopefully soon get some epoxy/filler primer ready for some paint and a fitting kit from Datsport.
I just purchased yet another SSS dash (round gauges) with the centre console and centre arm rest since they were in better condition than the bits I have, and the clock actually doesn't work on mine which was another reason to replace it with a better unit and someone had etched with a nail or something the km/h numbers since it's all in mph; looks dodgy as!
check out the link on my signature for some pics; I will be updating it soon since I will be getting stuck into it again this weekend coming.
