Nice one Graeme.
I'm personally a fan of Electrical gauges, only if the senders are fitted correctly!
If a wire is crushed, the signal dies, and you get zip. It's easy to check the line with a multimeter on the side of the road. (check light
With mechanical gauges, if you crush a tube, oil/water pisses out!
Electrical gauges are only as good as the power supplying them though (as you have said previously...)
Still I guess each to their own.
I've got:
Electronic Speedo,
Factory Tach,
Old 1600 water temp and fuel gauge (between tach and speedo)
Water temp
Oil Temp
Oil pressure.
Boost Gauge.
Because I don't have an oil cooler, just a big sump, i'm running the oil temp.
