It is currently Wed Jun 05, 2024 9:32 am
Post new topic  Reply to topic  [ 270 posts ]  Go to page « 114 15 16 17 18
 Post subject: Re: Datones 1600 project
PostPosted: Tue Jul 09, 2019 10:56 pm
Fuel tank overhaul... S13 cradle with walbro 255l pump
PostPosted: Wed Jul 10, 2019 9:51 am
Nice updates!
PostPosted: Wed Jul 10, 2019 8:14 pm
Yea good to see theres been alot of progress
PostPosted: Fri Jul 19, 2019 5:13 pm
Just caught up on the updates, too.......love that TD05 manifold and conversion!
For the in-tank pump with the S13 pump module, have a few questions if you don't mind:
a) did you have to shorten the pump support to fit the 1600 tank?
b) it looks like you machined the tank adaptor too?
c) how did you go with the fuel level sender, what gauge are you using or did you keep the stock fuel sender unit?
Nice job!
PostPosted: Mon Aug 12, 2019 12:15 am
Pista_510 wrote: *
Nice job!
From memory I did shorten the cradle a little and added a catch tray at the bottom to keep fuel surrounding the sock. The tank adaptor was just some 10mm plate cut out to suit the top of the s13 cradle. As for the fuel sender, I kept both the 1600 and s13 senders functional. I found the s13 sender was a better match for the s13 guage cluster I was using. Also gives you the added bonus of a low level fuel light👍
PostPosted: Thu Oct 08, 2020 1:06 pm
Covid Update: Started on the body work during the lockdown period. Found some rust in the front quarter panels and sill that was cut out and replaced. Slowly working my way around the car, door next on the list.
PostPosted: Thu Oct 08, 2020 1:09 pm
Front quarters...
PostPosted: Thu Oct 08, 2020 1:12 pm
Panel repair replacement from Nissco was good fit, need some modifying but not as much as i was expecting.
PostPosted: Thu Oct 08, 2020 1:15 pm
Rear sill section also need some attention. Pretty happy with the results.
PostPosted: Tue Nov 17, 2020 5:52 pm
Love the wheels! Real hashi's?
What specs?
And nice repairs mate
PostPosted: Mon Nov 23, 2020 3:28 am
How did you go with the fuel cooling did it quieten it down at all ?? as mine is also really loud when the weather warms up.
On a side note mine also when indicating to turn the whine pitch goes up and down with each flash of the indicators i should probably look into that..
datones wrote: *
Picked up and fitted a few more goodies tonight in preparation for summer. Lately ive become more aware of how noisy my fuel pump is, especially in the hot weather. On one occasion i was stopped at a set of lights and the guy next to me asked if everything was ok, granted it was a 35 degree day in traffic, but still it didnt seem right. Did a little bit of investigation and found something that surprised me, the surge tank in my system was getting quite warm. The small volume surge tank doesnt dissipate the heat as well as the main tank and it is this fuel which is feeding the main pump. With this in mind, i thought id trial something to see if it makes any difference. I picked up dual pass, inline transmission fluid cooler which i am using as a fuel cooler. Hot fuel from the rail passes through the cooler before returning to the surge tank. If i can keep the fuel cool, im hoping to reduce the heat being transferred to the main pump. Not sure if it will work as intended, but after researching i found it is quite common in diesel cars.
Also fitted up a knocklink detonation sensor, finishing off the LED install tomorrow.
PostPosted: Thu Dec 10, 2020 8:32 pm
chris1818 wrote: *
What specs?
Thanks, yes real hayashi streets. 15x7 all round. Starting to wish I went 15x7.5 in the rear.
PostPosted: Thu Dec 10, 2020 8:34 pm
6DEAN00 wrote: *
datones wrote: *
I ended up replacing the pump after a few summers and the new one was much quieter. Maybe I just got a dodgy one out of the box.
PostPosted: Fri Jan 08, 2021 12:41 am
Hey Tones, I'm interested in your new fuel pump setup. Have you had any issues with leaks, or fuel supply, since you did the conversion? Also, are you able to post some photos of how the pump sits with the tank in the car? I'm trying to gauge some ideas for my projects.
PostPosted: Sat Jan 23, 2021 9:59 am
green200b wrote: *
No leaks, I order a sheet of nitrile rubber to make a gasket to seal the Flange between the cradle and the tank and it seems to be working well. Here is a screen shot of some testing I did when creating a trough to keep fuel around the pickup sock.
