It is currently Wed Jun 05, 2024 3:40 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Wed Jan 22, 2014 7:37 am
im looking for a r180 diff for my 1600 and was hoping to find a 4.11. ive done a few searches online but im finding conflicting info and trying to narrow down if its worth grabbing the front diff from a diesel 720 4x4? from what i have read online it could be a 4.875 or a 5.14. the guy selling it seems to think it would be a 4.11.
What is the best way to tell the ratio if looking at the diff out of the car and what other things should i check for if any? for the ratio i remember something like taking cover off and divide the pinion teeth by the crown teeth? any help appreciated.
PostPosted: Wed Jan 22, 2014 9:23 am
i would be very suprised if it was a 4.1. It would be more likely 4.8 or 5.1.
I think 4.1 was from a s12 silvia or something
PostPosted: Wed Jan 22, 2014 4:06 pm
sd22 had the 5.14
sd25 had the 4.9
There will be an id plate on the vehicle which will have under axle type. if it says h51 (or something like that) its a 5.1, if it says h49, its a 4.9
the other way is to check the rear diff. If the diff has a cover on the back its a c200 diff and will have the 4.9. If the centre bolts in from the front its a h190 and then its a 5.1
:cheers
My experience has been with 5.14 diffs. The rears have all been pretty worn, the fronts are like new.
No idea what a 4.1 came from
EDIT
If its out of the car, take the back plate off the diff. On the cronwheel it will have a number stamped on it like 47/12. This will tell you the ratio
PostPosted: Wed Jan 22, 2014 4:54 pm
i was under the belief that the 4.11 and the 3.9 came from the petrol 720 4x4's. so for a couple hundred dollars would it be worth grabbing the 4.875 to sell or trade for a 4.11? 4.9 or 5.1 definately too low even for a weekend warrior but it may suit someone else?
PostPosted: Wed Jan 22, 2014 9:49 pm
diesels usually had the 5.1...
PostPosted: Thu Jan 23, 2014 11:26 am
5.1 is perfect for a peppy L16 or electric motor conversion with no gearbox :)
PostPosted: Thu Jan 23, 2014 12:56 pm
Some later 180BSSS 5speed ( True) & I believe some 200BSSS were fitted with R180 4.11 37/9
PostPosted: Wed Feb 05, 2014 8:23 pm
RAT510 wrote:
I was under the belief that the 4.11 and the 3.9 came from the petrol 720 4x4's. so for a couple hundred dollars would it be worth grabbing the 4.875 to sell or trade for a 4.11? 4.9 or 5.1 definately too low even for a weekend warrior but it may suit someone else?
Petrols were typically 4.6 or 4.875. The Z22 powered 720 I stripped recently had a C200 rear diff, 4.6:1 Ratio. Is there any use for these rear diffs, or should I bin it ? No bites on local gumtree listing. front diff might come up for sale if the diff in the other car is a 4.8.
PostPosted: Fri Feb 07, 2014 11:07 am
A long long time ago. I got a nismo catalogue :), which I cant find. :(
What I'm almost certain that I can remember is that the part numbers for crown wheel and pinions and other internal bits for c200 and r200 diffs was the same. This means that the c200 4.6 crown wheel and pinion should fit a r200 diff.
You will need to confirm this. 4.6 for the rally guys Z's would be good.
PostPosted: Tue Mar 04, 2014 4:00 pm
in my search for a 4.1 or 4.4 r180 i have learnt a few things i thought i might share. the 720 sd25 diesel front diff that i took a chance on turned out to be a 5.14. Before i even got it home i called in to see a guy about some more parts and he was happy to do a trade for some bits i wanted.
i managed to track down another diff from a 78 skyline and its a 3.9 r180 which is now cleaned up and in my 1600 shell until something better comes along.
recently i came accross another 720 sd25 diesel ute. from what i have picked up its most likely got a 4.8 in it as the code on the id plate states that it is a CA48 axle type. the reason i came to this conclusion is based on what stanza rally man stated above and the following info i found online. as with most online info i would only use this as a guide to help you establish if its worth pulling the diff from a car etc. the only true way to tell is counting teeth or turns etc. although there is no CA48 code below im making an assumption that it would have to be a 4.8 diff.
The axle code is located on the door jamb sticker on Nissans. If it's not there, there are visual ways of determining what you have. On some older trucks it's on a plate in the engine bay above the fender well on the passenger side.
HF35 - H190 axle found in 2wd Hardbodies.HF37 - H190 axle found in 2wd Frontiers
CA41 - Found on 720's - This is a C200/R180 combo with 4.11 gearing. Some 720's have the smaller H190 rear end that's identified by not having a removable rear diff cover. R180 front ends in 720's are different than the Hardbody and Frontier versions, as the diff is nearly centered. 720's use unequal length halfshafts and are not interchangeable. All 1986.5+ halfshafts are interchangeable left to right.
CA43 - found on 720's and Hardbodies. C200 rear / R180 front, 4.375:1 gearing
CA46 - found on Hardbodies and 4 banger Frontiers - C200 rear / R180 front, 4.625:1 gears
CA45 - found in 2003+ Frontier 4x4's. This is a C200/R180 combination with a new gear ratio - 4.5something:1 The C200 was upgraded to 31 splines on this model from the previous 29 spline unit.
HG43 - Found on Pathfinders, V6 Hardbodies, and a few '99 Frontiers - H233B rear / R200 front, 4.375:1 gearing. On the 2000+ 33 spline axles, the HG43 has a 4.363 ratio, however this is not a common axle code on the later models.
HG46 - found on auto equipped pathfinders, 96-97 hardody 4 bangers, many Xterras and Frontiers. This one has some variation. Pre-2000 versions are the H233B axle with 4.625:1 gearing (31 spline axles). 2000+ is the H233B axle with 4.636:1 gearing (33 spline axles). Typically comes with an R200 front axle, with the exception being in the '96-97 Hardbody pickups - those had an H233B / R180 combination. Axle shafts in the H233B were 31 spline up to about 2000, where they switched to 33 spline shafts. All Xterras and R50 Pathfinders received the 33 spline axles. In Frontiers, it can be a crapshoot if you have a '99-'00 model, though it is believed that the switchover was at or near 2/00 production date.
HG49 - found in mid year 2001+ Frontiers and Xterras. H233B / R200 combo with 4.90:1 gears.
I've learned recently from posts in NICOClub that there were some Hardbody 2wd's that appear to carry the C200 axle, but I've never actually seen one. If you have one, it's a rare bird. I'd love for anyone to post up their information and describe the year and model (I4, V6, XE, SE, etc.) of the truck that carries the C200 rear in the back of a 2wd so I can update my FAQ on my website.
Locker Selection:
ARB lockers are available for the older 30 spline C200's and all H233b's. They're also avaialble for the R200 front, however no traction device is out there for the R180.
Calmini LSD's will work in an R200 front. (A Calmini LSD is a slightly modified '87-89 Turbo 300ZX LSD)
Lockrights will only work in the older 31 spline H233B.
Detroit used to make a locker for the older 31 spline H233B, but those are getting scarce.
Up to 4.875:1 gearing is available for C200's and R180's. Up to 5.143 gearing can be had for H233B's and R200's. AC and SLR are the two companies offering gears, or you may be able to get them through Nismo.
Let's say you don't have the doorjamb sticker.
H190 - small 3rd member type axle found in 2wd's only (excluding Desert Runners, Xterras, pathfinders)C200 - removable rear diff cover, 8 bolts. Found in all Nissans (yes, even a few early 2wd Pathfinders)H233B - large 3rd member type axle found in most V6 and a few 4 banger 4x4's, Desert Runners, and 2wd Pathy's and 2wd Xterra V6's.
Other notes:
The H233B 3rd member changed from 9 bolts to 11 studs to hold it to the housing beginning with the 1990 models. Somewhere along this time (maybe around 6/89, the bolts holding the ring gear to the carrier changed from 10mm to 12mm, making a difference in replacement gear sets.
What do the numbers mean?
The number in the axle model indicates the size of the ring gear in mm.
R180 - 180mm ring gearH190 - 190mm ring gearC200 / R200 - 200mm ring gearH233B - 233mm ring gear (yes, that's about 9.25"!)
How do I figure out my gear ratio?
Put a jack under the diff and get both wheels under the ground. Draw a chalk line on the tires where they would contact the ground. Rotate BOTH tires by hand at the same speed one exact revolution while counting revolutions of he driveshaft. Just under 4 1/2 turns will indicate the 4.375:1 gears. Just a bit over 4 1/2 turns would indicate 4.625:1 or 4.636:1 gearing. If you have a late model, just a tick under 5 turns of the DS would indicate 4.90 gears.
LSD or open?
If you lost the sticker, get that jack back under the diff. Turn a wheel with the truck in neutral. If the other wheel spins in the opposite direction, you have an open diff. If it spins in the same direction, you likely have some sort of traction device - probably an LSD.
Additional Contributions:
Contribued by OnlyOneDR on N4W:
Tractions aids can be found for the R180 in the 720, Nismo, Quaife, Kaaz, and Cusco sell LSDs, mostly because the R180 was under the earlier Zs and newer Subarus. Not sure if you can swap the bolt retainer in from an open R180A carrier to get it to bolt into an HB or Frontier axle. I did that trick to get my 300ZX lsd into my R200A.
The HB and Frontier front axles are "A" axles, (e.g. R200A, R180A). The A designates an offset carrier. The R200/R180 are different because it is centered and does not have axle tubes on either side.
Contributed by OffroadX of N4W, AC, and XOC notoriety:
I'm not sure that the A in R200A etc. indicates an offset diff, from what I gather, it indicates a short-pinion diff. The Patrol uses offset front (and even rear) H233 diffs, but they're not designated H233A. I have seen in the Nismo catalog that the R180A was developed with a shorter pinion (by 120mm) to reduce driveline angles vs. the regular R180.
The R180A axle designation is RBThe R200A axle designation is RC
C200 and R200A gears ARE INTERCHANGEABLE. Yes, the same part numbers are used for the same ratios in the Nismo catalog for both diffs.
Best I can tell, 10mm ring gear bolts were phased out of the H233B diffs 6/86.
There are 5.571 and 5.875 gears available from Nissan/Nismo for the H233B
Regarding the H233B, the ONLY difference in Nismo 5.14 gears are at the 1990 model year. There were originally only gears for pre-90 diffs. AC sold a modified version of those for post-90 diffs, but a couple of years ago Nissan finally started making 5.14 gears for the 90+ diffs.
4.90 Xterra gears will go into any 90+ diff too
PostPosted: Tue Mar 04, 2014 9:54 pm
Essentially yes but alot of that info is American (xterra/frontier).
The key bit out of all that is read the id plate to be sure.
Ive always just remembered tho that the underpowered diesels needed the higher ratios like 5.1/4.8 etc and the petrols had the lower ratios 4.1/4.4 etc cos they had more grunt to push this gearing...
PostPosted: Wed Mar 05, 2014 7:46 am
Good point Nick regarding info being American and it would most likely vary from Aus delivered cars. Like you said read the id plate. Even then someone could have changed the ratios. The main purpose of my post was to just point out that there seems to be a pattern in the id plate codes in relation to the diff ratios and this could be used as a guide to establish what the diff ratio may be.
PostPosted: Sat Mar 08, 2014 10:16 pm
Just stripped the front diff out of an early petrol (L18) Datsun 720. And against what I was hoping, only has a 4.6:1 ratio diff ... damn ... so now I've got two of the things. This 720 came with the old 240K style 4 spd, chatting to a mate we came to the conclusion they probably had the slightly taller diff as there's no 0.8 overdrive on the box. Even with the wheel size and whatever, a 1:1 top gear and 4.6:1 ratio diff is going to be screaming at 100km/hr.
I've also pulled a 5.1 diff out of an early Diesel powered 720, but that had the 5spd box. So could well be that the 4.875:1 ratio only exists in 5spd petrol 720's or 4spd Diesel 720's. But I'm only speculating.
Interesting that the C200 diff might swap to R200's, will have to do some measurements and check it out. I'm only assuming it's a C200. Salisbury type rear axle, much heavier than the Banjo style found in the Petrol 720. Spring mounts are much wider and overall length (face to face) is somewhere around 1430mm. It's a much chunkier axle than the Banjo.
PostPosted: Sun Aug 24, 2014 10:03 pm
Hi, do you still have the 5.1 ratio out of the early diesel 720 ? Richard 0418566406
PostPosted: Fri Aug 29, 2014 6:35 pm
As a matter of fact, yes I do, but it's not for sale.
