heres the pic of the one I seen on Yahoo Japan. note the Nissan box, and new rear loom that came with the unit factory
This one ended up selling for something stupid like $500NZ!!! I cant remember exactly
heres the unit itself in its wierd glory.
This one cost me about $80NZ
theres 2 relays inside, one for each indicator.
normal state, all pins are connected together, and to the brake light signal.
when a relay is on, it switches to connecting the pins to the cam switches.
The cam is driven by a worm drive motor.
it has a small capacitor connected up also, which is there to make sure the cam stops in the same position each time you turn the indicator off.
the 6pin plug is all the "ins" brake and indicator signal e.t.c.
the 2 small 4pin plugs go to each of the tail lights.
I have only wired up 3 wires of each tail light so far....the 4th wire is wierd.
cant figure that one out......
4 wires...
1 = L1
2 = L2
3 = L3
4 = ???
L1 being the inside light ( first in sequence ), L3 being the outter light ( last in sequence ).
the 4th wire gets power at the same times as pin 1 ( light 1 ) when indicating, but does NOT get power when the brake lights are on.
Anyone got any ideas?
1970 KP510 SSS Bluebird coupe
