hey i just finished my 120y front brake upgrade
i went 200b struts and brakes, cause it's all i had lying around
had to cut 120y spring cups off the original struts and weld them at required height onto the 200b struts, install new shocks and use the 120y strut tops aswell.
used 200b lower ball joint/steering arm and lower control arm.
control arm might have to be shortened to get rid of excessive negative. i just moved the inner pickup point inward.
radius rod mount onto the lower control arm has to be redrilled aswell.
bit of modification but it is well worth it. Plus 4 pot caqlipers are easy enough to be adapted later.
_________________ Circuit Race 1600 in the build
