hello, i want to upgrade the brakes on my mr30 skyline. are front r31 & r32 discs directly compattible with mr30 struts? how much do r32 disc-brakes generally cost?
also what coilovers will fit mr30struts and how much do they generally cost?
r31 Aus brakes can be fitted to r30 struts, bolt on and there bigger.
According to my investigations & questions using a datsport caliper bracket the z32 calipers are bolt on using the right disc and separate hub, from a 180b/200b. I'm using 5 stud hubs on my r30 struts
The required brakes cost anywhere from $300 - $500 depending on where you get them from.
Yes there are coilover kits, Noltec make kits that will fit and I'm buying a kit in the 2 - 4 weeks so I'll post up the part number for you. Basically the kits are generic you just measure the outside tube diameter of the strut and order the required size from noltec or supplier. They cost about $250 for the coilover kit, then about $250 for springs and then about $400 for the strut tops all from noltec.
Hope this helps
for that kind of $$ you could look into an s-13 front end coilover swap?? just use the s-13 brakes, change to the 4pots and larger rotors if you want..
s-13 coilovers front $700 with adj chamber tops reco'd
s-13 hubs rotors and calipars $350 through forums second hand..
you'll need to get the rack ends for the s-13 and an extension made if you use the r31 rack...
you may not need larger rims if you use the s-13 brakes, r32 4pots 16" rims required and a low offset..
