Bought a new toy https://ozdat.com.au/forum/viewtopic.php?t=34700 |
Author: | limpn [ Fri Dec 29, 2017 1:33 pm ] |
Post subject: | Bought a new toy |
hey guys bought a new toy.. looks fairly original .. needs a good tidy up mostly but its 95% rust free .. so far I have fitted a new console / done a service / bought some new wheels as I don't like the hotwires I bought superlites just needs a good all round tidy up... |
Author: | unfamilia [ Fri Dec 29, 2017 3:08 pm ] |
Post subject: | Re: Bought a new toy |
Looks nice. What size hotwheels! |
Author: | limpn [ Fri Dec 29, 2017 4:03 pm ] |
they wheels on the car now are 13x5.5 the superlites are 13x6 |
Author: | unfamilia [ Fri Dec 29, 2017 4:10 pm ] |
Nice. Looks like a good base. Get onto the rust and cruise it around |
Author: | sutho510 [ Fri Dec 29, 2017 5:57 pm ] |
Looks neat did you buy it local? |
Author: | limpn [ Fri Dec 29, 2017 6:15 pm ] | |
Post subject: | Re: Bought a new toy | |
Yeah local to the gong |
Author: | b310gx [ Sat Jan 20, 2018 12:46 pm ] |
Nice buy, Australian assembled, easy conversion to a hydraulic clutch, so here's what I'd do. L18, 32/36 DGV, Stanza 5 speed, 1200 ute H165 diff housing with the 4.1 diff, Stanza struts with Stanza brakes, keep the vinyl roof & keep it as stock looking as possible. Great sleeper. The pedal box already has the hole & studs for a clutch master cylinder, you just have to drill the hole in the firewall & the clutch pedal. With the Sunny's you can bolt a Stanza crossmember in, but I'm not sure if this can work with the 120Y. Harry Kane (L18_B110 on 1200.com) used the original crossmember with the uprights from an L series Bluebird welded on when he did his turbo L20B 120Y. There are photos of the work he did in the Project Builds section of that forum. When he did his 1200 coupe he used a 180B crossmember. The best thing about 120Y's is their wheel wells, 7 inch wide rims fit easily under them, not like the 1200 or the Sunny. Above all, have fun in it. |
Author: | unfamilia [ Sat Jan 20, 2018 7:28 pm ] |
B210 can use180b X member but it adds bump steer. |
Author: | limpn [ Tue Jan 23, 2018 9:35 am ] |
Wow thanks for all that tech info I want to get the body and rust fixed in the next few months. I will respray the same colour.. later on down the track I would love to put an A14 in with a set of webbers. haven't thought about the diff but thanks for the reminder I have done some general tidy work on it .. removed stock clock and fitted factory tacho but new wheels on and tyres replaced all suspension bushes and ball joints - alignment done fitted new interior console and carpet new pedal pads new radiator hoses & thermostat heavy duty exedy clutch new air filter / plugs/ leads / dizzy / points / oil and filter ... maybe a few more... here are some pics of how it sits now with new wheels.. I cant wait to get the body fixed .. |
