Lights brighter with higher revs https://ozdat.com.au/forum/viewtopic.php?t=34293 |
Author: | Lenny21 [ Tue Aug 02, 2016 5:34 pm ] |
Post subject: | Lights brighter with higher revs |
Gday all, I noticed today that my electronics (headlights, dash lights, aircon) all get brighter/ stronger as I rev the vehicle. I cleaned the engine ground and no result. Any help would Be greatly appreciated. Cheers |
Author: | Barrell [ Tue Aug 02, 2016 7:37 pm ] |
Post subject: | Re: Lights brighter with higher revs |
Check the tension on the fan Belt (think you should be able to push it and it should have about 1 cm of movement). |
Author: | unfamilia [ Tue Aug 02, 2016 8:11 pm ] |
Check your battery voltage and although outputs at idle and at revs, to me could be an overcharging alt/ bad voltage reg |
Author: | nick [ Thu Aug 11, 2016 2:59 am ] |
Agree, sounds like a faulty voltage regulator... |
Author: | unlimitedpower [ Sat Aug 20, 2016 4:42 pm ] |
Over charging situation there, |
