Did a bit of reading:
The Evans stuff is a fair bit more viscous than water.
Water is a better heat exchanger than Propylene Glycol, but causes corrosion.
You don't have to run a pressurised system with the Evans stuff.
The Evans stuff has greater headroom until it boils
The way water transfers maximum energy is by converting from a liquid to a gas (boiling). The thermal transfer capacity of steam is far less than when it is a liquid, so once it's steam, it has to condense back. Bad if it's a hot spot in the engine...
At the end of the day Nissan's engineers used a 50/50 mix (or there abouts) of ethylene glycol and water (distilled). The system (say an SR20DET) would have been designed with this in mind and would have been life tested.
If you engine is running at above 120deg then I'd say it doesn't matter if your coolant can cope with it, the engine probably can't as it's not designed for this kind of temperature...
Does anyone have real world experience? I'm interested in some feedback!
