180B SSS boot lock rubber seal https://ozdat.com.au/forum/viewtopic.php?t=32449 |
Author: | Super [ Mon Mar 03, 2014 5:28 pm ] |
Post subject: | 180B SSS boot lock rubber seal |
Hey guys, Upon removing my boot lock the seal has disintegrated in pieces and Im not sure what to do... Are these still available for purchase??? Has anyone had the same problem and found a solution ?? Im worried if I install the lock without the seal it wont fit correctly and having the car newly painted I don't want to go through a trail and error process installing and removing the lock. Are the sedan boot lock seals the same? are they available? Thanks in advance FeZ |
Author: | Nissanman [ Mon Mar 03, 2014 5:36 pm ] |
Post subject: | Re: 180B SSS boot lock rubber seal |
I made a few seals for hinges and locks out of some 1.5mm sheet I found at Clark Rubber. These were for my '65 Fairlady. If it is a basic doughnut shape, easy to reproduce from stock |
Author: | Super [ Mon Mar 03, 2014 5:46 pm ] |
Thanks Nissanman, That was going to be my last resort... I just thought Id check to see if anyone can source some. Clark rubber aye, any idea minimum length width I can purchase? and you recommend 1.5mm? FeZ |
Author: | Nissanman [ Mon Mar 03, 2014 5:56 pm ] |
I think 1.5mm is the thinnest they stock. You can get it off a roll of say 50mm wide, sold by the metre or part thereof. Dirt cheap really. Alternatively, go to a Wrecker/Dismantler and remove some Nissan/Datsun locks and see what the gasket is like. Trouble is, there all getting old and brittle aren't they? |
Author: | 74SSS160J [ Tue Mar 04, 2014 1:48 pm ] |
DATMAN UK has the locks and seals new |
Author: | SSSBEE [ Tue Mar 18, 2014 11:08 pm ] |
How many pieces did it brake into? If you can roughly stick it back together and scan it I should be able to cut you one at work. |
Author: | chimp [ Wed Mar 26, 2014 9:43 pm ] |
Try "Spectrum Rubber". They are in Penrith. |
Author: | Super [ Thu Mar 27, 2014 10:05 pm ] |
Hey Guys thanks for you input, SSSBEE, Im not sure of the state of it but I will look for it as it may have been left at the panel beaters. Im currently talking with DATMAN UK and he seems to think he may have it new with the lock... If I fail I will be sure to contact you Cheers |
Author: | SSSBEE [ Sun Jun 01, 2014 12:45 am ] | |
Post subject: | Re: 180B SSS boot lock rubber seal | |
No worries mate, I may have a old seal on my parts SSS I can use as a template.
Author: | Super [ Sat Jun 07, 2014 10:01 am ] |
Hey SSSBEE, Your help would be appreciated... I cant get my hands on it, as I don't know where its disappeared to. I have a feeling the panel beater threw it out :S FeZ |
Author: | SSSBEE [ Thu Jul 03, 2014 9:38 pm ] |
Hey mate unfortunately my spare boot has no lock and the gasket is gone. |
