datsun 240k brakes https://ozdat.com.au/forum/viewtopic.php?t=27736 |
Page 1 of 2 |
Author: | Alex307 [ Thu Jan 12, 2012 6:31 pm ] |
Post subject: | datsun 240k brakes |
so i recently posted a topic asking what my struts nd brakes are on my 1600 and i was told they are 240k struts and brakes but i took the calliper to place here on the goldy to get a rebuild kit for and he couldnt figure out what one kit i need. as u can see they are sumitomo callipers but i cant find any info about them on the net. they do have the same brake pads as the 240k. also whats the best whay to get the pistons out? ![]() ![]() ![]() |
Author: | 24TKman [ Thu Jan 12, 2012 7:11 pm ] |
Post subject: | Re: datsun 240k brakes |
def 240k twin piston sumitomo's, i got the same set |
Author: | old-tin [ Thu Jan 12, 2012 7:22 pm ] |
+1. 240k to get the pistons out you have to undo the bolts and split the calliper. |
Author: | nathan 240k [ Thu Jan 12, 2012 7:58 pm ] |
240k brakes for sure |
Author: | Alex307 [ Thu Jan 12, 2012 10:08 pm ] |
We're can I get a rebuild kit from If I spilt the caliper apart will it just bolt back together |
Author: | nathan 240k [ Thu Jan 12, 2012 10:18 pm ] |
yes it will bolt back together and the rebuild kits should b easy 2 get im in tassie so im not sure were u would get them up there any brake specialist could order it in.make sure the pistons r right in before u put the pads back in |
Author: | Nissanman [ Thu Jan 12, 2012 10:25 pm ] |
To get the pistons out, just apply compressed air to the inlet connection. Put a piece of wood in the middle so that the piston[s] don't get damaged. ** KEEP FINGERS AWAY** |
Author: | nathan 240k [ Thu Jan 12, 2012 10:37 pm ] |
yes keep you fingers out of there ouch |
Author: | PSI510 [ Sun Jan 15, 2012 1:48 pm ] |
anyone got a part number for the kit for these and maybe also piston part numbers??? |
Author: | Nissanman [ Sun Jan 15, 2012 2:04 pm ] |
From my trusty PBR Cattledog: - Years 9/73 -1974 Minor Kit K918S Years 1974 - 11/75 Minor Kit K618S Years 12/75 - 9/76 Minor Kit K1184S Doesn't list pistons but if you take the whole kit and kaboodle to your local ABS workshop, they will inspect the pistons and advise if they need replacement. Usually, any scratch or pitting that you can catch your fingernail on, is unserviceable - new parts required ![]() Some shops are using composite pistons now instead of the hard chrome steel ones ![]() |
Author: | 24TKman [ Sun Jan 15, 2012 4:10 pm ] |
ive pulled apart single piston 240k/200b brakes and they have the same size pistons as the twin opposing piston callipers IIRC |
Author: | MYDATO [ Sun Jan 15, 2012 4:55 pm ] |
If you split them you will need to buy the little sealing rings that sit in the grooves of each caliper to get them to seal properly again. |
Author: | Nissanman [ Sun Jan 15, 2012 5:10 pm ] |
They are usually included in the seal kit. The clamping bolts are done up really tight though ![]() |
Author: | Alex307 [ Mon Jan 16, 2012 3:51 pm ] |
i couldnt undo them their so **** tight also got the pistons out and took them into a place and they measured up as 240z pistons? |
Author: | MYDATO [ Mon Jan 16, 2012 10:47 pm ] |
Yep 240Z's used the same calipers. You'll need a good impact gun to undo the bolts. I ain't talkin about anything to can buy from supercheap either. |
