if you're getting a hydro handbrake then you don't really need to bias to the rear IMO.
Not quite true. HAnd brake is more for the slow tight stuff where you want the car to turn into hairpins etc, whereas rear brake bias keeps the rear end moving around under braking at higher speeds. You don't want it to start swapping ends under brakes, but you do want it unsettled under brakes (on gravel). This makes it much easier to turn in to corners, and easier to deal with the unknown (eg. going sideways into a corner helps you scrub off speed if the corner tightens etc)
Also, on gravel the grip levels are lower, so you will have less weight transfer under brakes. That's why you need a bit mroe rear bias just to balance the brakes out, let alone getting more braking at the back.
Using the handbrake (steering stick) while racing is something that takes time and practice. Mostly I don't bother if I can get a decent pendulum happening, specially if the bias is right so you can get the tail wagging under brakes at will (controllably, not snapping out and trying to overtake you). It's really only the slow speed stuff coming into a tight hairpin where I use the handbrake to bring the back around.
