It is currently Tue Jun 18, 2024 5:55 am
PostPosted: Tue Sep 13, 2011 2:31 pm
hhhhhhhhhhhhhhhi
ive got an L20 in a 620, bosch 715 coil and SII bluebird elec distributor
ive wired them together including a relay for the coil, im getting 12V at the coil (when i pull the plugs from it and measure it from there, with it measured across the terminals i get 10.1V)
the relay is supplying switched power to the positive terminal on the coil (nothing when key is out of the ignition, 12V when key to IGN), ive got a wire from negative battery terminal to the negative terminal on the coil
the dizzy is wired to the coil, green wire goes to negative on the coil, pink wire is to positive on the coil
no spark :( the coil heats up though, quite a bit too
any ideas greatly appreciated :D
1972 P510
1979 620
PostPosted: Tue Sep 13, 2011 3:17 pm
Remove cable from battery to negative coil terminal and it should work OK.
PostPosted: Tue Sep 13, 2011 6:09 pm
Yep no need for the neg post on the coil to be connected to the battery.
PostPosted: Tue Sep 13, 2011 10:24 pm
nice! thanks lads :D
1972 P510
1979 620
