It is currently Tue Jun 18, 2024 4:05 am
PostPosted: Sat Jun 04, 2011 5:26 pm
Hi all,
I'm trying to id the parts circled in the pic below.
I think green is the fuel pressure reg?
PostPosted: Sat Jun 04, 2011 7:35 pm
Green is indeed the EFI pressure regulator.
Red is the EGR valve, Exhaust Gas Recirculation.
Purple is either fuel supply or fuel return.
Blue is a thermo valve for a vacuum source?
I think!
PostPosted: Sun Jun 05, 2011 12:03 pm
Thanks Nissanman
The egr valve has a vaccum hose on it. what should i connect this 2.
will the standard fuel pressure reg be ok for a turbo?
That fuel barb is not the return or supply, these are seperate, is there somewhere else fuel needs to go or can I block this off?
PostPosted: Sun Jun 05, 2011 12:58 pm
Vacuum to brake booster possible?
1979 Datsun Stanza Coupe
1979 Datsun Stanza GX
1982 Datsun Stanza GX
1966 Nissan Cedric Custom Six
1972 Volkswagen Beetle
EziAutoParts
PostPosted: Sun Jun 05, 2011 1:25 pm
stoutcatcher wrote:
Thanks Nissanman
The egr valve has a vaccum hose on it. what should I connect this 2.
if you have feed and return there is no need for that Tee that i can think of. it would normally have been pipe, so a straight bit of hose end to end would do.
that little sensor, just after the throttle body, could??? be an air temperature sensor of sorts.. why it has a vacuum line to it, not sure, unless it's for cold starts.
the Z18 efi had a sensor right after the throttle body on the intake for that same reason.
PostPosted: Sat Jul 09, 2011 8:49 am
the last 2 things are
blue = extra fuel jet
purple = extra fuel jet feed
ding! ding! ding! i won the million dollars!!!! :woohoo:
if you arent going to use it then pull it out, or plum it up, put a plug on it and run the wires back into the loom to make it look propper, you dont want no po po telling you that your missing a vital senser or some Krap!
i think that the reason for the jet is becaue of the poor ecu that was used on these engines, i mean if you open up the original trottle position senser you'll fin that it is just a 2 or 3 position switch (closed, mid and open!)
also I think that the jet is in backwards. if you pull it out you will see a 25mm long shaft with a tiny nozel in one side, i think it is supposed to point away from the butterfly
hope this helps
Dannoss
donuts when burnt will emit a blue flame indicating a high energy content, however consuming donuts will make you fat.
Burning Nitromethane emits a white flame indicating a higher energy content than even donuts, running this in your engine will give you a fat.
thanks fergs
PostPosted: Mon Sep 19, 2011 8:12 pm
RED - EGR. I did away with this
GREEN- FPR - Fuel Pressure regulator
BLUE - Cold start injector
PURPLE - Cold start injector fuel feed
Have a look....
http://ozdat.com/forum/viewtopic.php?f= ... 2&start=15
