I painted the front bar of my B120 some years ago.
From memory I sanded it with #80 paper and after cleaning and metal prepping it to condition the surface, sprayed it with rattle can etch primer.
I did the backside as well because we all know they look daggy in there.
Then some sandable Primer Surfacer.
Followed that with 3 or 4 coats of Gloss Black enamel and it came up sweet.
The key is to prep. the bumper or whatever
properly and then you can re-finish it just like any other panel.
Flaking chrome needs to be scraped back to a solid surface and any rust has to be buffed up to remove the worst, then treated with Metal Prep.
You need to pay particular attention to the seams and joins, if any, to make sure there is no corrosion hidden in there.
Body Filler, if used, will probably only bond successfully to any bare metal.
However you could use Automotive Seam Sealer to fill any seams or joins to smooth out the appearance.
Use the Seam Sealer AFTER you have coated the item in Etch Primer to avoid rust appearing later on.
![[ attachment ]](./download/file.php?id=17170&t=1&sid=7f85e7ee85895822b86e6b18a930592d)
Not a real good pic. but here you go.
No corrosion showing and the paint is still tough and nice and glossy
Dent knocking and welding of bumpers in my experience is a
pain.
The metal is under so much stress from the pressing at manufacturing that I found the bar would crack when the weld cooled.
Brazing can be used to fill some dents but distortion is a possibility.
Some bars of simpler construction, i.e. a simple pressed "U" shape would be easier to work on since they are relatively stress free.
Anyhoo, what have you got to lose?
Have a go cause it is a LOT cheaper than chroming
P.S. I wouldn't recommend Powder coating or 2Pak paint.
Being a bumper, it needs to flex and the above two products may not handle that too well.
Just my opinion
![Wink :wink:](./images/smilies/icon_wink.gif)
