Fitting r32 4 pot calipars to r31 struts https://ozdat.com.au/forum/viewtopic.php?t=220 |
Author: | Guest [ Tue Apr 15, 2003 5:23 pm ] |
Post subject: | Fitting r32 4 pot calipars to r31 struts |
I have a set of four pot r32 calipars and was wondering what was the best/easiest strut to attach them to. ![]() This is for my 1600 |
Author: | Jonk [ Tue Apr 15, 2003 7:41 pm ] |
Post subject: | |
Pretty much everthing is gonna need custom mounting brakets for the calipers... |
Author: | dattoman1000 [ Tue Apr 15, 2003 10:01 pm ] |
Post subject: | |
Contact Stewart Wilkins Motorport 02 4577 2400 He makes a bracket assy to fit these to 1600's. He doesn't have any stock at the moment but the brackets are at the fabricators being done now. I spoke to him yesterday about this exact thing. |
Author: | Guest [ Tue Apr 15, 2003 10:55 pm ] |
Post subject: | |
bolt onto R31 GTS and S13 struts |
Author: | Ben [ Tue Apr 15, 2003 11:00 pm ] |
Post subject: | |
that post was from me.....forgot to sign in ![]() |
Author: | jimmy [ Thu May 08, 2003 12:40 pm ] |
Post subject: | brakes |
and how well do the s13 and r31 gts struts bolt into a 1600? |
Author: | TRX910 [ Thu May 08, 2003 5:59 pm ] |
Post subject: | |
s13, you need the s13 hubs, struts and lower control arms r31 you just need the strut, with the wheel hub.. re-drill the disc for 4 stud, bolt on the caliper, fit brake lines etc etc and you're finished! you'll also need rims with sufficient clearance for the 4 spots |
