sr20 converted https://ozdat.com.au/forum/viewtopic.php?t=17791 |
Page 1 of 2 |
Author: | fragard-303 [ Fri May 29, 2009 11:41 pm ] |
Post subject: | sr20 converted |
hey guys I was wondering if anyone ever tried putting twin webbers on an sr20. i have never herd of any and would love to see one done and how well it goes. |
Author: | Rat Dat [ Sat May 30, 2009 2:16 pm ] |
Post subject: | Re: sr20 converted |
There's a guy here in Ballarat who has put carbies on an LS1 5.7litre V8... i just dont get it... why put an inferior means of petrol delivery on a hi-tech motor? I have heard of someone putting webbers on an SR20, but again, i just dont get it.... |
Author: | Boyracer [ Sat May 30, 2009 6:53 pm ] |
Why - Because you can... or don't want to go to the cost of computers, efi fuel pumps and regulators and all that cr@p. On a newer car I owuldn't think it'd amke a lot of sense. If you can find a manifold to fit the webbers you'll be laughing, piece of cake... but what are you going to do for spark ? The SR20 doesn't come with a dizzy does it ? |
Author: | spandex [ Sat May 30, 2009 6:55 pm ] | |
Post subject: | Re: sr20 converted | |
Why you need a dizzy for? and yes they do come dizzy,If you can find a manifold to fit the webbers you'll be laughing, piece of cake... but what are you going to do for spark ? The SR20 doesn't come with a dizzy does it ? Webbers would work from on a NA, a NA is dizzy anyways, DET has a CAS, but it will work with either |
Author: | fragard-303 [ Sun May 31, 2009 12:48 am ] |
haha dont need a dizzy .... i found a DIY job that might do the trick http://www.jaycar.com.au/productView.as ... rm=KEYWORD and if you make a face plate that bolts to the head and one to the carbie/s i recon it may work |
Author: | bob260 [ Sun May 31, 2009 12:56 am ] |
I have never really completely understood the 'because you can' justification. I *can* jam a broomstick in my backside and stick pictures on the internet - I don't because that would be an inferior option to *not* doing it. The cost justification doesn't hold water either. By the time you have reconditioned two webers and found/manufactured a manifold you are looking at way more money than the factory fuel delivery. |
Author: | 24TKman [ Sun May 31, 2009 8:36 am ] |
twin weber SR20!!!! no rev limiter.... sounds like fun |
Author: | Rat Dat [ Sun May 31, 2009 12:24 pm ] |
To me, it's like putting a wooden wheel from a horse and cart on a drift car. |
Author: | spandex [ Sun May 31, 2009 1:02 pm ] | |
It limited when it snaps at 9k from a rocker arm smashing to bits
Author: | datdrift [ Sun May 31, 2009 3:42 pm ] |
couple things to consider if you bolted the carbies to a face plate and straight to the head is will the carbies get to hot secondly is it goin to have enough length between carbies and valves for the flow to pulsate properly either get a manifold or just go efi |
Author: | fragard-303 [ Sun May 31, 2009 10:23 pm ] |
well what i have found is to go with efi you need a money tree with the carbies you can tune them from home instead of going to a dyno $$$$$ an with the carbies being bolted is not an issue i just need to design a manifold |
Author: | bob260 [ Sun May 31, 2009 10:38 pm ] |
Why do you need tuning? Run the factory computer and loom, the factory already did the hard work, |
Author: | fragard-303 [ Sun May 31, 2009 10:40 pm ] |
so racing a standard computer is going to give you a gold meldal |
Author: | Boyracer [ Sun May 31, 2009 10:41 pm ] | |
Why you need a dizzy for? and yes they do come dizzy, Webbers would work from on a NA, a NA is dizzy anyways, DET has a CAS, but it will work with either I might be speaking out of my arsk as I'm not familiar with this CAS ? The Jaycar programmable ignition is no good for you, only has a single ignition driver so not suitable for running a set of coils even in wasted spark config. Will work as an interceptor on an existing ignition system. Check out the 'Electrical' subsection of the forum. A set of 45's are going to struggle to get 2L to 9k, if you really want it to go that hard you might have to look at 48's. |
Author: | bob260 [ Sun May 31, 2009 11:01 pm ] |
Well, it depends on the competition. A carby SR20 would probably take the gold medal if you are racing Formula Fail. |
