I helped OLDSCL install one in his 4dr a few months back.
Assuming yours is a >70 model, the radio brackets should have 4x mounting holes in them that line up with the holes in the steel dash frame structure (the vertical members either side of the radio hole).
Once mounted into the dash frame, the radio should be in the perfect position for the plastic surround to slide over it from the front. Then the plastic fascia panel goes over the potentiometer shafts and is secured by nuts and washers.
_________________ SR20DET 1971 Datsun Bluebird 1800SSS Coupe - 11.58 @ 122.40 MPH 18PSI GT2871R and PLMS NIStune
Historic 1971 Datsun 1600 Wagon - L series nostalgia
Historic 1967 Datsun 1000 Wagon - A series resto
