i adopted an orphan - 200B Wagon https://ozdat.com.au/forum/viewtopic.php?t=14616 |
Page 1 of 2 |
Author: | redsky [ Sun Oct 19, 2008 10:43 pm ] | ||
Post subject: | i adopted an orphan - 200B Wagon | ||
My first foray into Datsun ownership is this light Blue 200B wagon. I'm sure it will be a change from the Skylines and Triumphs i've had in the past, for starters, i'll fit more in the back. It's a 1980 GL model with a bit of rust in most doors & behind the wheel arches, which will keep me busy for a bit. The interior is excellent for a 300k km car, with just a saggy drivers seat to show for it. car has bee fitted with a 5 speed and central locking at some stage, which is a handy bonus. Don't know much about the mechanicals (apart from it runs & doesn't blow smoke) as it's not on the road yet. A new clutch went in last week.
Author: | redsky [ Sun Oct 19, 2008 10:46 pm ] |
Post subject: | Re: i adopted an orphan - 200B Wagon |
File comment: I really like the updated front of these later models. Even has the original headlight protectors.
Author: | James May [ Mon Oct 20, 2008 8:48 am ] |
Looks awesome! Very clean and tidy. The rust is in the normal places, by the sound of it. Hopefully it won't give you too much trouble. More photos? |
Author: | redsky [ Mon Oct 20, 2008 10:03 pm ] | |||
Post subject: | Re: i adopted an orphan - 200B Wagon | |||
The car needs a new dizzy cap & occasionally jumps out of 1st if you dial up the revs a bit quick, but other wise drives nicely.
Author: | redsky [ Mon Oct 20, 2008 10:06 pm ] |
I noticed the datsun sticker on your bonnet, looks great. where do you get those? |
Author: | nitros13 [ Tue Oct 21, 2008 12:25 am ] |
set of mags, on its ass, will look very tuff. |
Author: | James May [ Tue Oct 21, 2008 9:22 am ] | |
Ebay. A guy called "stencilmaster" sells them from his ebay store.http://cgi.ebay.com.au/DATSUN-3-colour- ... dZViewItem There's a link to the item. |
Author: | green200b [ Tue Oct 21, 2008 5:47 pm ] |
That looks quite clean actually. I have lots of 200B parts here if you need any and am also wrecking a 200B wagon now. I'm guessing by the plates you're in in Victoria? If so where? |
Author: | redsky [ Tue Oct 21, 2008 8:21 pm ] |
Thanks for the comments peoples, I've got some mags sitting around that will probably end up on the car at some stage, either Triumph S 14"s, or if i can spare the dollars i'll get new tyres for the Silhouette 15"s. Don't know quite when i'll put it on the road yet, looks like a hot summer coming up here near Shepparton & there's no aircon. I guess its not real easy or cheap to retro fit. |
Author: | James May [ Tue Oct 21, 2008 8:58 pm ] |
It's not too hard, if you can find an original aircon setup from a 200B. Just need to get it regassed. |
Author: | redsky [ Thu Mar 26, 2009 9:43 pm ] |
Post subject: | Re: I adopted an orphan - 200B Wagon |
The 200B finally goes in for a RW check tomorrow....after 5 months of sitting around the back yard it's about time too. I'm a bit nervous, hope they don't find anything too nasty in there. I know it'll need a few rubbers in the front end some exhaust manifold & muffler work. Lets hope thats all, it is meant to be a cheap & cheerful run around. |
Author: | SSSBEE [ Thu Mar 26, 2009 11:12 pm ] |
nice 200b wago mate ![]() |
Author: | green200b [ Fri Mar 27, 2009 4:05 am ] |
Good luck with the roadworthy! |
Author: | FIZZLE [ Fri Mar 27, 2009 7:14 pm ] |
thats an awesome project and in such good nik!! really nice 200B ![]() ![]() ![]() |
Author: | redsky [ Fri Mar 27, 2009 10:36 pm ] |
Well, that didn't go too bad after all. Following a thorough inspection all it needs is castor rubbers, front brake flexible hoses, re kit a rear wheel cylinder, fix a broken passenger seat mounting bracket, rear muffler & exhaust manifold gasket. Not bad for an Ebay cheapie with an excellent interior. It gets me thinking though - how much for a set of extractors while doing the exhaust and do seats from later nissans bolt straight in? ( drivers side is a bit lopsided) Should be on the road within 3 weeks if i pull my finger out. |
