Hey guys,
As most of the info so far has been mechanical I thought I might contribute something on the EFI side of things.
The CA's are blessed with a rather capable system. Which Mr. Nissan calls ECCS. It is very similar to that of the SR20 with a couple of notable differences : the CA can be tuned without needing to fit a daughterboard like the SR, and the CA missed out on the "Consult" diagnostic port - which is kind of a bummer. But not the end of the world.
The bottom line is that the standard EFI system is perfectly useable for engine conversions. It's quite flexible and, being AFM based, it will handle mild modifications without a re-tune.
But the best part is that if you want to have a play, the CA's ECCS system is very easy to re-tune yourself. All you need is a PC, an EPROM burner and some free software called ROM Editor. Remove the standard chip, fit a socket, then start tuning. Removing boost cut and changing RPM limit is a doddle. Then once you're familiar with the basics you can start looking at bigger AFM, bigger injectors etc. The sky's the limit. Many people think that because you are using the factory system that there's some sort of limit to the power you can get from it - totally untrue.
And the best part is that you'll have an engine that still retains perfect manners (and fuel useage) even once it's quite highly modified. For those willing to do some tuning themselves the rewards are considerable.
PL
Ok that sounds all well and good that you can tune them "yourself" but what good is it going to do you if you don't have access to a Dyno ????
On road tuning isn't really a viable option either.
I'm not having a go at you, just that it isn't as easy as you make it out to be.
