how do u do that
i had to change mine in the 1200 ute i had, but the clutch one, same sh*t different smell...
the pushrod is the bit that comes out of the master and connects to a U sorta shape thingy which has a bolt through it which goes THROUGH the brake pedal.
to move the pushrod further down, just drill a new hole in the pedal 15mm further down, and adjust the U thingy to suit... or mod your pushrod to suit...( i havnt looked at the normal one jsut comparing to my old one i had in the 1200)
its only so as u dont use as much pressure or use more swing of the pedal, i cant remember exactly y but i know it made sense at the time i was told it haha
like changes the pedal pressure TO pedal swing ratio to suit the new master and booster better??? sumthing along those lines...
