Well the dff is in the car!!!
As DAMO666 suggested, I ground out the casting inside the diff casing for clearance to fit the VLSD centre and 4.11 crownwheel.
Fitted perfectly...
I then took it to a local diff and gerabox bloke who set it up for me and she's all done....
One thing of note: The crownwheel bolts for an open diff are shorter than the LSD bolts. [b]So make sure that the LSD bolts are used!!!!!!! [/b]In the later ( 94 on ) Suby diffs all the bolts seem to be 11mmx1.25 thread. The Datsun bolts are 10mmx1.25.....
So in summary: For a R160 4.11 VLSD you need:
4.11 ( or whatever ratio you want ) open diff from auto Suby ( preferably 94 onwards )
Post 94 VLSD Centre from any Suby ( WRX most common )
Change tailshaft flange on open diff from Suby to Datsun
Grind out casing on Suby housing ( make sure you seal up the inside of the diff with rag and tape so no metal shavings get into the bearings as the pinion will still be in there).
Take housing, crownwheel, VLSD centre, side covers and bolts, all the shims you can find ( get them of an old datto diff or something ), O'rings and importantly, the LONGER LSD BOLTS, to a diff bloke and he'll be able to set it up fine...
Oh, and get your halfshafts modded to suit like I did...
Remember all this is only if you want to go the way of the circlip type LSD. I know it's easier to got the earlier type but due to lack of supply and prices, this is an alternative.
Oh: I'll plug D&M Diff and Gearbox repairs in Ipswich.. He knows his stuff and charged me only $50 to set up the diff. Yes...$50..I couldn't beleive it....
So all up the Diff, VLSD centre and setup cost me $340 in total.
The drive shafts were done for nothing.
Hope this helps some people out there...
