SO... This is the plan that I have come with. It is completely theoretical at the moment as I don't have the engine or box to check everything out. Everything is pointing to this idea working out ok though.
The "chassis hugger" would go either side of the chassis right near the steering mounts... or even inline with the steering mounts. The physical room SHOULDN'T be an issue and the exhaust getting past from the turbo should not be an issue either.
To create a little more room up front, the standard X-Member will be modified to create a bigger arch forward. This could also double as a bit of forward support for the engine if it is needed... which it shouldn't be but, having the options, is never a bad thing.
There SHOULD be plenty of room for some lengthways bracing as well. Other than that, there SHOULDN'T be too much else in it.
Theories are nice.... wait and see how we go when I have the engine and box and can get the thing dummy fitted... when we can do that... we'll KNOW how much of the tunnel I will chop, how much further back the shifter will go and where things will fit nicely....
I think this KIND of setup will go ok.
Anyone have any thoughts... feel free to share
