I offer a change-over service with new stainless steel pins and full bronze bushes installed...with greasing capability...ie BETTER THAN NEW!
There are 3 options.
1. For your convenience I can send rebuilt front or rear TOP HINGES and require your old one(s) back later, meaning no car down-time.
These will be sandblasted and coated in acrylic grey primer.
A $10 security will be added and refunded on receival of you old hinge(s).
2. You can send your own, (where time is not a factor and you don't wish to repaint) and receive them back fitted with a kit and as much care taken of your paint as is possible. Turn around time approx 2 weeks.
3. Finally, and only for those with vice and 8mm reamer, I can send kits of bushes, pins & grese nipples for DIY installation. For ideal tolerances, reaming is done after bushes are pressed into position.
Pricing is as follows Option1. $35 (+$10 security), Option 2. $30, Option3. $25.
Discounts will apply till 5/10 on Left & Right pairs....$60 (+ opt. 1 security), $50 for opt. 2 and $40 for opt. 3. .... WITH FREE POST TO YOU:
Weigh this up against $19 for 2 x nylon bushes alone.
For quotes contact
wayne@davmon.com.au
