It is currently Wed Jun 05, 2024 2:40 pm
 Post subject: 200B Sway Bar Upgrade
PostPosted: Mon May 03, 2010 7:58 am
Not sure if this info is common knowledge, but couldn't find any mention of it in the archives so thought I'd post this up.
I've found the R31 pintara sway bar to be an exact fit in my '77 200B. This gives a nice little upgrade from the standard 20mm bar to 23mm, and there's no issues with clearance when running an L series engine.
I used the 200B d-rubber brackets with no issues.
See photos below:
Apparently the R31 skyline item is thicker again, can anyone confirm this?
DATSUN - All that style for so little money
In the shed: '69 1600 (Destined for Autocross)
'70 1600 (Eventual Daily)
On the road: '81 VH SL/E
'88 V6 Pathfinder
PostPosted: Tue May 04, 2010 2:45 am
I did not know that.
How much of a difference does it make? Or have you not driven it yet?
BM510 wrote:
I'm a driver.
PostPosted: Tue May 04, 2010 7:53 am
Haven't driven it yet, the car is a couple of weeks away from being registered.
Although 3mm difference probably doesn't sound like much, the bar certainly looks and feels a lot 'chunkier'.
I also note that Maddat offer an upgraded swaybar for SR20 into 200B conversions which is 22mm in diam.
I will let you know how it handles on the road, but I reckon these things are probably worth next to nothing from the wreckers, so even a small improvement could be considered good bang for buck. :thumbsup:
On top of that it is literally a 5 minute job to change one.
'88 V6 Pathfinder
PostPosted: Mon May 17, 2010 9:31 am
does anyone know if this would bolt up to a sss 180b??
PostPosted: Mon May 17, 2010 9:55 am
Interesting....i might have to try this one :).
PostPosted: Tue May 18, 2010 12:19 pm
If you're in vic, you can have my old 200B sway bar when I've done this conversion. If that bolts up, then the R31 pintara swaybar will fit.
BM510 wrote:
I'm a driver.
PostPosted: Tue May 18, 2010 1:35 pm
I just remembered i have my old S12 swaybars in the shed, I'll have to see if they fit, probably very similar.
PostPosted: Tue May 18, 2010 8:33 pm
import HR31 GTS is bigger dia and has ball joint ends.
Wanted 200B doors-prefer yellow
1978 GX Auto.
R30-910 Bluebird
R31 Skyline-Passage GT-Pintara
PostPosted: Tue May 18, 2010 9:39 pm
i heard this from craig ford ages ago to try awsome nice work there man i just bough the mad dat one for when i installed the sr
1600s arent the only datsun
PostPosted: Wed May 19, 2010 8:41 am
Thanks for that info. Can anyone confirm the diam. of local R31 Skyline bars?
'88 V6 Pathfinder
PostPosted: Tue May 25, 2010 9:28 am
I can confirm that this makes a noticeable difference on its own, and a hell of a difference when conbined with stiffer lowered springs. Even running 185/75 14's all round, stock rear suspension, and a subtle lowering of 1" down on standard at the front, the car feels very 'firm' through the bends with a dramatic reduction in body roll.
In stock trim this car really did handle like a mid size barge, and felt very loose through the bends.
This is how the car sits now:
I'm happy with the all round stance, and as it appears the stock rear coils have sagged over the years I will simply match their height with stiffer items.
This combined with some wider/lower profile rubber should see her sitting and handling at a level I'm happy with for a daily driver.
'88 V6 Pathfinder
PostPosted: Tue May 25, 2010 11:40 am
Yeah, The IRS models had terrible springs and shocks for some reason and they all seem to sag like that. Fortunately, it's quite an easy fix. Though not many people seem to know this and every IRS 200B I've ever seen has had this problem.
BM510 wrote:
I'm a driver.
PostPosted: Tue May 25, 2010 6:33 pm
Yeh was also wondering if the R31 skyline sway bar is the same as the R31 pintara ? :?
wagonman (Greg)
1981 720 Twin Cab Ute L20 5spd
PostPosted: Tue May 25, 2010 7:28 pm
As far as I can tell, it should be. They share exactly the same chassis. Best way to tell is to go to a wreckers, pull a sway bar off a Pintara and a Skyline and see for yourself.
BM510 wrote:
I'm a driver.
PostPosted: Wed May 26, 2010 9:16 am
To answer your question, Nope it wont fit.
The shackles are different shape and use different bushes, I looked into using 200B shackles when i couldn't find the square bushes for my Datsport swaybar.
"You stay classy OzDat"
