trb012's Datsun 120y 2door sedan Z18 Turbo http://ozdat.com.au/forum/viewtopic.php?t=9796 |
Page 36 of 39 |
Author: | d [ Tue Jan 19, 2016 4:47 pm ] |
Post subject: | Re: trb012's Datsun 120y 2door sedan Z18 Turbo |
this angle in HD quality would suit a full wall picture in any garage |
Author: | trb012 [ Wed Jan 20, 2016 11:05 am ] |
Thanks D. |
Author: | trb012 [ Thu May 12, 2016 4:06 pm ] |
Small update time been driving the y a bit lately taking it to local shows and the occasional drive to work have come up with 2 immediate issues I need to fix. Firstly is the less than average fuel economy (expected when on E85) but Im basically filling it up every time I drive and getting around 160km to a tank. To rectify this I've finally got around to fitting a flex fuel sensor so can be tuned for 98 on the street and 85 for the track so far have fitted the sensor and started modding the return line to suit. Also have picked up the correct speedflow fittings and plug to wire it up should be done in the next weekend or so then off for another tune. Second issue is that it's starting to like putting on a smoke show when sitting idle for too long have narrowed it down to valve stem seals or leaky exhaust seal in the turbo. Will get valve stem seals done first then go from there hopefully resolves the issue all though an excuse to upgrade to a gtx2863 would be cool . Have also picked up a GL rear tail light infill panel for a bit more JDM street cred should look good and will match the gx dash when I find a gx badge for it |
Author: | SR20Datsun [ Thu May 12, 2016 4:48 pm ] |
Nice update Stu. How old is the turbo and what kind of Turbo are you running? Can you pick up a second handy to prove it isn't the valve seals? |
Author: | trb012 [ Thu May 12, 2016 7:46 pm ] |
Turbo is just the standard Z18et one that was rebuilt and high flowed 10+ years ago so probably getting abit long in the tooth. I'll get valve stem seals done first anyway as there cheap and can do without pulling the head off using leak down tester. |
Author: | sik 510 [ Fri May 13, 2016 4:45 pm ] | |
Post subject: | Re: trb012's Datsun 120y 2door sedan Z18 Turbo | |
That's pretty average economy. Does the MS run 02 closed loop/lean cruise setup? Getting that running on our FJ netted massive economy numbers. We drove it to hanging rock from Mornington and back on half a tank, making it 9-9.5ltr/100km.
Firstly is the less than average fuel economy (expected when on E85) but Im basically filling it up every time I drive and getting around 160km to a tank. To rectify this I've finally got around to fitting a flex fuel sensor so can be tuned for 98 on the street and 85 for the track |
Author: | trb012 [ Fri May 13, 2016 8:26 pm ] |
No I don't but yeah should look into that on the next tune. We we're pretty rushed doing the initial one before dat nats so probably a few things that need tweaking. |
Author: | Azzdat16 [ Sat May 14, 2016 5:12 pm ] |
Love this 120. What suspension are you running? Sorry if u have already mentioned earlier in the thread! |
Author: | trb012 [ Sat May 14, 2016 9:39 pm ] |
Rear suspension is pretty basic just reverse eye reset springs with koni red shocks. Front is 240k struts converted to coilovers with a T3 kit,275 pound springs,T3 camber tops and koni yellow z31 inserts. |
Author: | Azzdat16 [ Sun May 15, 2016 12:26 am ] |
How do you find the Technic toy stuff? I have been looking at their coilovers |
Author: | trb012 [ Sun May 15, 2016 11:11 am ] |
Pretty good had no issue's with the coilovers alot of mates are running them on there dattos too without drama's. |
Author: | d [ Sun May 15, 2016 1:30 pm ] |
If the smoke gets worse in the future is there a plan for a L20B bottom end or L20B crank in that block? |
Author: | trb012 [ Sun May 15, 2016 8:31 pm ] |
Compression and leakdown test both point out the bottom end is healthy enough for now. If it ever decides to expire will build what I have or go 2.2 stroker. |
Author: | trb012 [ Thu Jul 14, 2016 9:35 am ] |
Y will be on display on the fuel magazine stand at motorex this weekend. If anyone's going come up and say hi. |
Page 36 of 39 | All times are UTC+11:00 |
