It is currently Tue May 21, 2024 7:42 pm
Post new topic  Reply to topic  [ 240 posts ]  Go to page « 111 12 13 14 15 16 »
 Post subject: Re: Tyrie's 120Y
PostPosted: Wed Jul 09, 2008 2:29 pm
Currently it has the jellybeans and whitewalls off my 120y, it will get these once I get some tyres:
PostPosted: Sat Aug 16, 2008 3:05 pm
after 3 months off the road not making any boost I decided to have a look at it, turns out the little BB in the boost controller had gotten stuck so adjusting it had no effect. easy fix. Then it started playing up something terrible, I couldnt figure it out so i took it over to autotech, who found that the cam belt had jumped a few teeth on the crank... So it is now getting bigger injectors, new reg and retune with more boost :) Hoping for 160-170kw but will have to wait and see.
PostPosted: Sat Aug 16, 2008 6:02 pm
Ahhh! I hadnt seen the 120y with those rims. I was following you the other afternoon at Glenloch interchange, you went south and I went north. Looks great on the road, love the pea shooter.
$2000 challenge bluebird - no more.
RPS12 - 80s-o-rama. Currently dropping 200cc, gaining a cam and gaining a turbo.
PostPosted: Thu Aug 21, 2008 9:33 am
:D
PostPosted: Sat Aug 23, 2008 12:01 pm
Finally ran a 12 last night :D
PostPosted: Sat Aug 23, 2008 12:23 pm
Nice one! That is turning into one quick little Y!
PostPosted: Tue Sep 16, 2008 1:06 pm
A little too quick, as it turns out... :evil:
If anyone wants to have their 120Y/1200 running 12s they should buy this and put the goodies in their car ;) $5700.
PostPosted: Tue Sep 16, 2008 1:26 pm
meaning?
PostPosted: Tue Sep 16, 2008 2:05 pm
I am guessing loss of license?
PostPosted: Tue Sep 16, 2008 3:01 pm
hmm close to it. Also defect which was more annoying :(
PostPosted: Tue Sep 16, 2008 3:11 pm
I feel your pain... im gonna have my car on the road soon but im gonna be losing my license for something as trivial as crossing white lines... :evil:
PostPosted: Wed Sep 17, 2008 1:40 pm
So I've been thinking of stripping the 120y. It wont happen before uni ends mid/late november but I'd like to gauge interest before I start pulling it apart.
Here's a list of bits, I've probably forgotten some minor stuff.
Whole car take it away today $5700
$500 - 15x8 (2) and 15x6 (3) chaser wheels, 225/50 tyres (2) 205/55 tyres (3) 185/55 tyres (2)
$180 – Maddat 22mm adjustable swaybar
$1100 – Shortened R31 sillhouette LSD diff
$300 – Stanza struts, 180B inserts, king springs, corona hubs, magna rotors, cortina calipers
$300 – Rebuilt 120Y booster with 15/16” master cylinder
$100 – OBX Daytona black fixed bucket + rails
$150 – steering wheel/boss, door trims, dash etc
$80 – Wilwood adjustable brake bias valve+lines
$50 - Clutch master setup suit 120Y
$20 – Solex locks + all keys
$80 - 2.5” mandrel bent Exhaust dump back (not including dump)
$100 – 13x5.5” hotwires, tyres
$200 120Y fuel tank with extra fitting/s, lift pump, surge tank, 070 main pump, 3/8” main line.
$3800 - Complete engine package. 165rwkw 15psi.
Otherwise –
Engine AE92 4agze (160psi on all 4) - $1000
T50 gearboxes (2) - $400
Autronic SMC+loom+modified CAS - $1200
Custom Nissan T3 turbo, highflowed, polished front housing, Ceramic coated rear. Custom ceramic coated steampipe manifold (fits ae86 and 120y, probably others), 2.5” dump pipe, Speedflow braided oil feed line/Tpiece. Sump with oil drain, Braided water lines. Autometer Pro comp ultralite boost gauge+cup. $1300
200mm exedy brass button clutch $100
550cc injectors $200
365cc injectors $100
RWD bigport inlet manifold with TVIS removed $150
Cut/shut (well) smallport inlet manifold suit RWD $150
Blitz BOV with pipe $100
Alloy radiator+fan $250
Custom FMIC (fits behind 120Y grille) $100
Engine/gearbox mounts to fit 4ag+T50 into 120Y $200
Located in ACT. email tstarrs72@hotmail.com.
PostPosted: Wed Sep 17, 2008 2:28 pm
what was the defect?
is it then able to be registered in another state easily if the defect isn't cleared
PostPosted: Wed Sep 17, 2008 3:49 pm
its a recall notice not a defect as such. Means it has to go over motor registry pits. Most people get around it by cancelling the rego then getting a normal inspection and re-establishing rego. Not so easy in this case.
So yeh ACT recall notice shouldn't mean anything in another state, but you'd still need to engineer it to get rego, which I dont think is worth while.
PostPosted: Wed Sep 17, 2008 4:23 pm
very tempting Tyrie! I have a couple of 120Y's I could put your parts to good use in. I'm thinking a 165rwkw Wagon would be alot of fun...
