ok this is really peeing me of and no one can seem to tell me what the problem is.
datto 1600, 5speed sr20de.
i have this 'clunking' through out the driveline when i change gears.
it is worst when going from 1st to 2nd or from reverse into 1st other gears it still happens but not much.
feels like something is still spinning after the clutch is put in and i have to force the stick in place against it
also with this i get a very notchy feeling gearchange.
example:
driving in 1st.......clutch in...notchy feeling when pulling out of first.....clunk clunk through in to the diff (sounds like it anyway)......notchy in to 2nd ....drive drive.
first thought was uni joints but on inspection feel great with no play in them.
had a spare diff with half shafts (good unis) and swaped that in to eliminate the diff...absolutely no change.
gearbox? had that inspected and new bearings etc last year so hopefully shouldnt be that?
air in the master cyl? so clutch not fully dissengaging? will bleed tonight if i have the time to eliminate this. though i can understand the notchyness for this but not the clunking.
drive shaft...uni's are good with no play but might be some play were it mates to the gearbox. this could be the clunking but not notchyness? why would this start to happen quite suddenly?
anyone got other ideas or similar experiences? it feels like something is about to brake.
oh, car seems almost fine when thrashing it at the track though
feels worst at very low revs with hard acceleration
