-- Datsun 1600/P510 Project by SR20Datsun -- http://ozdat.com.au/forum/viewtopic.php?t=6579 |
Page 76 of 77 |
Author: | SR20Datsun [ Wed Oct 31, 2018 1:11 pm ] | ||||
Post subject: | Re: -- Datsun 1600/P510 Project by SR20Datsun -- | ||||
For some reason, having access to aluminium cylinders in the grade that was capable of supporting water wasn't available, so I had to roll some up out of flat sheet metal.
Author: | SR20Datsun [ Wed Oct 31, 2018 1:13 pm ] | ||||
Now came the fun part; fitting the custom designed baffle, made from some nice anodized thin sheet. Slotting straight into the catch can cylinder. The idea is the vapor laden air goes onto the 'inlet' side, snakes it way down through vent holes, to a variety of strategically placed vent holes all the way down to the bottom, then passing all the way up the other side to the outlet on the side facing away. Any oil that gets caught gets captured in the bottom. If it gets full past the bottom layer, the efficiency decreases dramatically, but there would be trouble with the engine if this happened anyway. The lower picture shows the thought processes going on in my head on how to mount this sucker. Welding brackets in place and making it removable from each other would allow repairs if anything failed or needed modification.
Author: | SR20Datsun [ Wed Oct 31, 2018 1:19 pm ] | |||||
Post subject: | Re: -- Datsun 1600/P510 Project by SR20Datsun -- | |||||
A few years pass (check the photo dates!) before I conjure up enough time/motivation to get stuck back into it again. Mounting up in the car before welding and tweaking the brackets always pays dividends. Using Aeroflow screw top, and the proprietary blue tack for bonnet clearance measurements. Using the most advanced assembly method known to mankind...masking tape. After checking fitment, it was taped and marked up ready for welding. Now, I am rusty as all hell with aluminium welding (pun intended?) and some attempts and getting my eye back in failed dismally. I'll blame the TIG on that... Impatience led to getting a well known company to work their magic. Canfred Engineering in Bayswater (VIC) to the rescue. Top job and quick turn around. It also pays to know which materials you used when asking to weld this stuff up.
Author: | SR20Datsun [ Wed Oct 31, 2018 1:30 pm ] | |||||||
Post subject: | Re: -- Datsun 1600/P510 Project by SR20Datsun -- | |||||||
Assembly is always a good part of the project. I designed the washer bottle to use the old Datsport washer bottle motor, luckily there are replacements should I need a new one of EBay. The motor is mounted on its own little bracket with some zip ties to hold it in place. Not yet polished finish. Air that is cleaned by the catch can will then flow back into the inlet pipe after the Air Flow Meter. Therefore I had to weld in a stainless ORB fitting using the new TIG. (see I told you it was the TIG...) Making up custom piping is always a pain. Cutting that stuff and fitting it onto the connectors does my head in. The old saying measure twice and then cut, usually becomes measure 11ty and cut twice... Routing this would feed hot oil vapor carrying air into the catch can where it would be caught and fed back into the inlet (closed loop per ADR). Any condensate captured would be drained at the beginning of the next day. I also can route the drain into the sump, but that's a later project. The finished product all polished up, ready to be fitted. I decided to remove some material on the bracket that holds the contraption to the strut tower to make it look nicer and weigh 12grams less, why? Because. Overall a very satisfying project on the car. Going for a drive, I was impressed by how much moisture the catch can captures. Daily driving to work didn't capture much oil though, so I will have to wait until the next track day! (which may be never unless I sneak one in before the twins come...) Might have to throw some paint on the strut tower brace bracket... Wait, there's a mini project! YES!
Author: | sutho510 [ Wed Oct 31, 2018 6:23 pm ] |
Nice work mate . Thats a massive effort |
Author: | SR20Datsun [ Thu Nov 01, 2018 8:27 am ] |
Hahaha... Yes for something so 'simple' as a catch can and a washer bottle. |
Author: | Lurch [ Sat Nov 03, 2018 6:15 pm ] |
Tidy work as always Nik |
Author: | lampy [ Sun Nov 04, 2018 8:02 pm ] |
Looks great Nik |
Author: | SR20Datsun [ Thu Nov 08, 2018 7:12 pm ] |
Thanks gents. Seems to do the trick. |
Author: | trb012 [ Mon Dec 17, 2018 4:19 pm ] |
Top job as always mate |
Author: | Lurch [ Tue Feb 19, 2019 9:54 pm ] |
We will miss you and your updates Nik See you somewhere over the rainbow......................... |
Author: | SR20Datsun [ Tue Feb 19, 2019 11:04 pm ] | ||
No-one reads this stuff anyway
Author: | RJB510 [ Wed Feb 20, 2019 7:18 am ] |
I'm still here occasionally. |
Author: | Lurch [ Sun Feb 24, 2019 10:15 pm ] | ||
Page 76 of 77 | All times are UTC+11:00 |
