Team Dat's 120Y Koop *update 15/10/13* http://ozdat.com.au/forum/viewtopic.php?t=6564 |
Page 14 of 14 |
Author: | Datski [ Fri Jul 31, 2009 10:38 pm ] |
Post subject: | Re: Team Dat's 120Y Koop *update 31/7/09* |
just get the whole car dipped in chrome...and in the sunlight noone can look at all the bad parts! hehehehe, i am always partial to a dark colours but that wont help you to hide stuff, just pic a colour you like just not hot pink like my misses ex boyfriend.....120y bright pink with moon and stars all over it, while she drove a 720 4wd....was funny to see |
Author: | Team_dat [ Mon Aug 03, 2009 12:49 pm ] |
well i think i have settled on my colour, and will be doing the Megasquirt route. anyone who has used one of these and has had any nightmares or suggestions on where to get my sensors and that from post here |
Author: | racer135 [ Tue Apr 27, 2010 8:24 pm ] |
Any progress? |
Author: | Lurch [ Tue Apr 27, 2010 8:57 pm ] | |
Post subject: | Re: Team Dat's 120Y Koop *update 31/7/09* | |
Any progress?
Bwahahahahahaha......
Author: | Team_dat [ Sat May 15, 2010 9:01 pm ] |
oh racer you sir are a champ, i did go out and look at it last week, and i also thought about giving her a wash down and maybe tinkering again.... who knows maybe ill finish before the 10 year mark? |
Author: | burubado [ Sun May 16, 2010 7:07 pm ] |
respray it factory colour i reckon... and get some japanese round tails looking forward to seeing progress |
Author: | racer135 [ Mon May 17, 2010 10:09 pm ] | |
oh racer you sir are a champ, I did go out and look at it last week, and I also thought about giving her a wash down and maybe tinkering again.... who knows maybe ill finish before the 10 year mark?
Yeah that sounds like the progress on my datsuns. Look at them for a bit, clean something, walk away wishing they could fix themselves...haha But from last month I decided that every second weekend had to be a Datsun weekend, the old man is getting the sh&ts with the 120Y taking up the workshop hahaha!
Author: | Team_dat [ Tue Oct 15, 2013 6:44 pm ] |
So......... The coupe needs to be on the road by NYE so i can have a car. the commo daily is long in the tooth and i want her back. i'm excited. she wont be all turbo and sh*t but she will have the twin SU's. anyone got any ideas on a linkage setup to go L-series SU to A series cable throttle? |
Author: | MangaNOID [ Tue Oct 15, 2013 8:24 pm ] |
no idea on linkages but man this is along time since updates. get cracking! |
Author: | Team_dat [ Sat Oct 19, 2013 7:55 pm ] |
Post subject: | Re: Team Dat's 120Y Koop *update 15/10/13* |
well i fly home from work on wednesday, so i will commence works thrusday, i have to get an idea on how everything is from when i left it. and then hit it hard. i want to give it a light recoat of the factory colour and also paint the engine bay black. i want this to be a smooth as possible rego process... fingers crossed! |
Author: | b310gx [ Sat Oct 19, 2013 11:08 pm ] |
I've been looking at the same problem for my Sunny that's getting a L20B with SSS carbs, & this is what I thought of doing. It appears the U shaped bracket the rod hooks into is held in place with a screw on the other side of the support. This part of the linkage then slides out. My idea was to get the main shaft from a dead carbie, with the thread on the end & see if this could be substituted for the U shaped bracket. You could then use the throttle plate that comes with the carbie to attach the cable to the linkages. Or if you had access to a lathe, to make a shaft with the proper thread that woud fit inside the linkage. You'd have to fabricate a bracket to support the throttle cable, but I've seen bluebirds with a similar set up to the 120Y & am going to try to find a bracket from there. Or you could just use a downdraught weber & use the A series bits. Not as sexy as twin carbs, but a bit easier to set up. |
Author: | Team_dat [ Sun Oct 20, 2013 7:38 am ] |
Cheers for that, I'll look into it. I did have a 32/36 on it before but I have the su's there and want some dual carb action!! |
Page 14 of 14 | All times are UTC+11:00 |
