It is currently Mon May 06, 2024 5:59 am
 Post subject: Crownwheel Bolts Sheared
PostPosted: Thu Mar 31, 2005 2:08 am
Okay, took the car to scrutineering tonight, and was left revving it in the middle of the road...
5.1 in a 240K R180 housing, with a welded centre. The Crownwheel and Pinion aren't that old (Late 2002), and have only done <8 rallies. Was set up by a professional diff shop for pinion depth and such.
All the crownwheel bolts had sheared, and were sitting in the bottom of the diff when we pulled the rear hat off. And a couple had made a daring attempt at escaping through the top of the diff housing, leaving a 5 cent piece sized hole on the top left of the diff, and some great gouge marks inside.
Has this happened to anyone else?
I'm planning on Dev-Conning the diff housing, and re-installing the crownwheel on the centre with UnBrako bolts, predrilled for lockwiring?
Suggestions/Thoughts/Derision?
Brindabella Motor Sport Club - www.bmsc.com.au
2007 Navara TurboDiesel UberTruck, 1973 180B Saloon, 1976 180B Rally Weapon.
PostPosted: Thu Mar 31, 2005 2:56 am
So was there the stock metal tabs locking the bolts in the first place ?
PostPosted: Thu Mar 31, 2005 9:07 am
Nup. But there was none when we pulled the diff apart the first time (when the new ratio was installed).
I noticed there was some on the spare diff that's now in the car.
Guess that'll explain a bit of why this happened!
Will lockwire suffice instead of the factory lock-tabs?
PostPosted: Thu Mar 31, 2005 10:12 am
Yes lockwire is probably even better.
