DatwillDECm8,
(damn it man, shorten your name
it takes too long to type out!)
Ok where to start....
In the windshield gutter (or plenum chamber) water does sit in that area. BUT there are meant to be baffles which stop water from 'pooling' in the areas where the tubes go down from the plenum chamber to the guards. The baffles are the first thing to make sure they are not rusted out. So what you do is clean them up the best you can, weld up any sections requiring welding (in your case could be alot!
) Remove ALL the rust -using a 'sandblasting' gun, (but use garnet, cause sand is bad for you lungs.) then spray a nice 2k paint or etch prime over the top. THEN (the secret bit) use a Sikaflex or other sealer to make sure she's water tight, then put primer over the top of that, then put your 2k or whatever tickles your fancy. You must do it in that order for best rust prevention.
Trust me I know someone, who knew someones sister, who's brother had a friend, who knew someone, who robbed someone, who knew a painter..... (or something like that -could be that I have just finished my paint job....Thanx to my painter!)
The baffles should stop the majority of water from getting into this area, with the main drain in the front of the firewall (right behind the cylinder head) taking care of most of the water. This stupid thing DOES block up with leaves. The secret to this is to remove the sheet steel in front of the drain (your brake T section is mounted to this, so make up an aluminium bracket to suit.) This allows the leaves and stuff to move a little more freely, and at the same time means you can poke it all out (with a stick....
) and make it free draining.
Make sure when you paint, you cover every bit of steel.... Anything you dont cover after painting, paint in fishoil or Wurth rust preventative wax. Its the dux nuts. I found making up some nozzles connected to the bottle of goo and poking them round all the enclosed areas which didn't get a dose of paint worked the best.
So in answer to your question about the guards.
The amount of water going to this area should be minimal, and if you paint your guards correctly and seal up the sections were one panel is joined to another on the guards, you shouldn't have a problem as the water will just run off. (theoretically speaking. -my car is only just getting parts put on it!)
Hope all this helps...
