OZDAT
http://ozdat.com.au/forum/
Is my diff stuffed (video)
http://ozdat.com.au/forum/viewtopic.php?t=34698
Page 1 of 1
Author:  Hatchman [ Sun Dec 24, 2017 11:15 am ]
Post subject:  Is my diff stuffed (video)
Hey all
Not an expert on these things, I just put the car up on axle stands as I thought it was the gearbox that is stuffed but... maybe not?
https://www.youtube.com/watch?v=i7bSKBbNFlM
Author:  unfamilia [ Sun Dec 24, 2017 1:51 pm ]
Post subject:  Re: Is my diff stuffed (video)
What kind of diff is it? Single spinner or lsd
Author:  Hatchman [ Sun Dec 24, 2017 1:56 pm ]
Standard 1600 diff I believe so single spinner
Author:  sutho510 [ Sun Dec 24, 2017 6:22 pm ]
Does it make noise? It could be something else like a brake issue
Author:  Hatchman [ Wed Dec 27, 2017 11:33 am ]
I thought it could be brakes but with the car on stands and running through every gear with the handbrake on there is a very noticeable "clunk", "clunk", "clunk" sound coming from the passenger side of the car where the wheel is not spinning.
She'll go in to the mechanic on the 8th to confirm but based on two mates of mine who are ex-mechanics I'm pretty much calling it that it is the diff now.
The bugger is I don't have a spare diff so I'll have to bite the bullet and get this one repaired. There are a couple of good places in Frankston that will reco a whole diff so while it is in the shop I'll see if I can get the ratio's made a bit taller and maybe see if they can make it into a bit of a mild LSD while they're at it - not sure how feasible this is with a standard 1600 diff but maybe I'll get lucky
Author:  sutho510 [ Wed Dec 27, 2017 2:25 pm ]
If your going to spend that sort of money why dont you bite the bullet and put a r180 lsd in it
Author:  unfamilia [ Wed Dec 27, 2017 10:01 pm ]
Suby conversion hooooooooo
Author:  Hatchman [ Fri Dec 29, 2017 10:57 am ]
I thought that... but then that would require more work to CV shafts, maybe tailshaft too right?
Not against it, just don't really have the time/skills on my side
Author:  limpn [ Fri Dec 29, 2017 12:29 pm ]
I'm not sure but I have had this happen in a previous car ( non datto) it was wheel bearings seized ..
Author:  Hatchman [ Fri Dec 29, 2017 3:37 pm ]
No sh*t?
Hmm hadn't thought of that.... maybe that is it....
Author:  sutho510 [ Fri Dec 29, 2017 5:24 pm ]
No if you go r180 it will use the same shafts that you have now(unless you do a subaru r180 conversion)
Author:  Hatchman [ Tue Jan 09, 2018 12:47 pm ]
And it is the diff.
I have a spare though so I can get it back on the road. Will look into an R180 as a project down the track, anyone have a decent step-by-step guide on one?
https://www.phpbb.com/
