OZDAT
http://ozdat.com.au/forum/
ca20 vs ca18 Gearbox
http://ozdat.com.au/forum/viewtopic.php?t=34689
Page 1 of 1
Author:  120ynat4 [ Wed Nov 29, 2017 7:43 pm ]
Post subject:  ca20 vs ca18 Gearbox
what are the big differences between a ca20 gear box vs a ca18 box.
I know the ca18 box is supposed to be shorter but just want to see if anyone has any experience with the two boxes
Thanks
Author:  nebuchernezzer [ Wed Nov 29, 2017 9:53 pm ]
Post subject:  Re: ca20 vs ca18 Gearbox
Ca20 has an external (ish) attachment of its gear lever. I don't recall if the lengths are different. The gearstick sticks up in a different location i think though.
Been a looong time since I've had the boxes next to each other sorry.
Author:  bluebird68 [ Fri Dec 01, 2017 8:18 am ]
Thanks
The ca20 box is the earlier FS5W71b with a ca bellhousing for series 3 bluebird/pintara.
The ca18 box is later desigh FS5W71c for silvia /180sx and as already mentioned has different shifter setup although both boxs are same overall length. Go with the later one,
Author:  Imago [ Wed Dec 06, 2017 9:33 pm ]
The later box is sooooo much nicer. It is roughly 50mm longer from memory and the gear stick position is further back. But as bluebird68 mentioned it's a later design and closer to that of an SR20 box and similar to an RB20 box without a 3rd main bearing.
https://www.phpbb.com/
