I'm wondering what temps you guys are running with sr's in your dattos. I've recently put air con in mine and now I cannot keep the temps low especially on these summer days. I've tried water wetter and racing coolant but temps on a 30+ degree day with aircon on will hit near 120c in traffic. Anyone else had the same problem? Any suggestions on solutions?
Are you running an SR20DET?
How big is your thermo fan?
One of the issues I used to have was hot air would rise from from the engine bay (turbo/exhaust) and also after the intercooler/radiator while the thermo fan was on, would come out the top of the bonnet (all along where the big gap is between the bonnet and where the bonnet catch is) and then get sucked straight back through the intercooler/radiator again. It would just circulate!
I pop riveted some small aluminium L section underneath the bonnet and attached some rubber seal over that to seal the underside.
I also added some folded aluminium sheet on the sides of the radiator area to make sure air is being ducted through the radiator and not around it. Seems to make a fair bit of difference in peak hour traffic. Haven't trialled it on the race track yet.
The heat generated by the air conditioning condenser would add to the amount of heat entering the engine bay/radiator. Having a way of getting air from the front of the car outside through all of these will require some careful ducting IMHO. so when the fan kicks in, you are actually getting air through the whole lot.
