It is currently Wed May 15, 2024 6:21 am
PostPosted: Thu Oct 06, 2016 9:00 am
Thinking about a bike conversion into my 1200ute? Anyone done it or links will be great thanks Adam :thumbsup:
PostPosted: Thu Oct 06, 2016 10:34 am
I have investigated this for my P410 sedan. Things to consider;
[*] Gearbox - do you intend on using the gearbox from the bike? If yes, you need to consider that there is no reverse with a bike gearbox, so options are to do some expensive machining and stuffing around to mate a gearbox up OR most use a starter motor on the tailshaft to achieve the same. Just understand the limitations of a gearbox that wasn't designed to be moving a lot of weight, and a starter motor that probably isn't to well equipped to rotate a big weight limit either.
[*] Where are you located? You may not legally be able to do the conversion in your state, I haven't found much information on this. There are conflicting opinions, some seem to suggest the bike engine once removed from a bike becomes a "engine", therefore with that thinking as long as the vehicle it came from passed emissions technically there should be no issue achieving engineers. Others suggest you simply cannot put a bike engine in a car, again I haven't found anything to back up this opinion.
[*] Assuming you use the bike gearbox, you'll need an adaptor to convert the gearbox spline to a flange that is compatible with a tailshaft. Apparently some buggy places in the USA sell these for certain bike engines.
[*] To mount the engine you'll have to create some sort of frame, doesn't look too difficult, the ones I have seen seem to use round stainless thick solid bar that goes around most of the engine then mounts to the chassis/crossmember via usual methods.
[*] You'll be making your own extractors most likely.
Check out this guys car for some good details, I love this thing
http://www.speedhunters.com/2014/02/a-k ... nja-power/
It isn't a great deal different from doing a normal engine conversion, other than the extra bits mentioned above. Cool things you will get;
- Noise!
- Sequential shifting
Hope that helps.
PostPosted: Sat Oct 08, 2016 9:33 pm
I don't know the weight of a 1200 ute but I think it is at least 4-5 times heavyer so it wil be not so fast without torque.
'83 Laurel C31 VG30DET
'84 Patrol 160 L28E
PostPosted: Mon Oct 10, 2016 11:17 am
Google says around 730kg for a 1200 ute, you make a good point though, especially if the OP plans on taking passengers or is heavy him/herself.
PostPosted: Thu Feb 02, 2017 11:40 pm
Lol you guys haven't seen videos of bike motored cars before if you think it'll be slow. Once you're out of first gear they hammer. I remember an escort built 15 years ago with a sc28 motor over in europe YouTube it its rad as.
Busa motor with a tune good header system and intake filters and feeds will make 180-220 crank HP without looking at cams. They have plenty of torque just given that the max power comes in it 10500 rpm or 10,000 rpm itll take a bit more under the band to get going then something that makes peak hp at 6000 rpm with same weight. Once its on noise it'll be a rocket and as a motor that's renown for low down torque in a bike with big peak HP its a good candidate.
Users browsing this forum: Google Adsense [Bot] and 1 guest
