I filled my chassis rails, door sills, a and c pillars (I don't have a b pillar). chassis cross brace, k frame, rear arms and any other place I thought it would help with special 2 part expandable foam. Got the idea from Baz and then enquired about it with others that have done this. It is water proof and it stiffened my chassis enormously. My car now drives totally different and you can feel the suspension work. I know Rally cars and drift cars do the same also . I chose to go this way as I did not want to install a cage.
Its quite cheap stuff, however the problem is that you can only buy it in small amounts overseas and the cost of shipping blows it out of the roof. Or you can buy a whole heap of it from Oz but then alot will go to waste because you wont use it all. noone is oz sell it in the small amounts.
Note it is a very messy process as I pours out of every hole that exits in that space! and the product will expire about 2 months after you break the seal.
Do not use expandable foam in a can from bunnings as this will not set correctly when the oxygen in the air inside the rail runs out. The reason being is that the 2 part stuff is not dependent on oxygen for the reaction, but on the the two chemicals that are mixed. The bunnings stuff reacts with Oxygen to work so its not good in enclosed places. The bunnings stuff also has a lesser density when it sets and I dont think its water proof.
Super,
This is an incredible plan!!! This little bit of info is why I posted this thread
I have gone through the linked thread above but, if this bit of advice is there, I missed it. My car is a shell at the moment so, when I know where everything will be going, this is probably going to happen. I have a few mates with race cars so I might have a chat with them about splitting the bill for the foam and sharing the goods between us.
Really appreciate the reply mate, AWESOME bit of info!!!
I added 50mm box tube along inside of sils, from cage main hoop to firewall. Not exactly an easy mod for a car that's finished, but a great way to strengthen front end of car during paint n panel stages. Pics are in my build thread, you can hardly tell its there with scuff plates and black carpet
DAT04,
This is the straight forward approach that was in my head to do. I will DEFs be checking out your build thread for some images on what you done did.
Thanks for that mate
