Hi guys,
When I got my car back together after doing the FMIC/intake manifold/electric waterpump/etc etc, I noticed the alternator ran a little low. It sits around 12.5-13 and drops lower and wants to stall if the thermo comes on while I have the headlights on, so driving at night is a no-no at the moment. I don't know if I've done something wrong or wired it back up the wrong way, or if the EWP is dragging it down, but I've bought a second hand RB30 alternator for it, as I've heard they bolt on. I just need some help with the wiring.
Here's a picture of the RB30 alternator on the left, and my current alternator in-position on the right. Sorry for the bad photo, but it's the best I could do, short of hiring someone from the circus to contort themselves enough to take a better one.
From what I can tell on my current alt (right of picture), I have wiring from my loom connected to B+ and another couple of wires bolted to the top right corner which I am assuming is ground/earth? Easy enough.
Here's where it gets different. My car has a single white wire with a red spade connector which connects to D+. On the RB30 alternator, the D+ terminal is being used by the capacitor, which the other end is bolted to D-. On my car, the capacitor is bolted to ground/earth, and the other end connects to B+.
The other difference is the black box (regulator?). On the RB30 alternator, it has wires coming off it (which have been cut off, just out of the picture). On my alternator, it's a standalone unit.
So my question is, can I re-wire the RB30 alt to match my current setup, i.e:
- Bolt the capacitor to earth/ground at one end, and B+ at the other, and;
- Remove the black box with wires coming out of it and replace it with the standalone one from my current alternator?
Any help is appreciated! Also, if anyone can see any problems with how my current alternator is wired that might solve the issue, that would be awesome because it would save me having to swap in this new one!
