It is currently Fri May 17, 2024 10:29 pm
 Post subject: bike carb tuning help
PostPosted: Sun Sep 07, 2014 8:37 pm
Got some car time today. Need some 58mm id pvc pipe to test diy runners of 100mm to see if pod filters will work on them well. Mine was too big 60mm. Air pods made fuel come out air vents again. They block air flow to the jets in the intakes.
With mesh runs like it did, idles at 1200rpm nicely . Lean if idle below 1200rpm idle.
Wide band says rich everywhere else. Stumbles and no power. Main Jets must be too big at 1.7mm. Need a day on dyno!!!
now has anyone had any success with bike cv carbs on cars?
Ive got new 1.3mm main jets to play with and if needed prepared to drill til right afrs on dyno.
Can the pilots be drilled for more low down flow like mains?
Im so close but no time to get onto dyno. Looking for some advice from those that have played with bike carbs.
