Hello All, After much dicking around my new Works 72 cam arrived the other day. Now for the install, but before some questions need answering.
1: Just to confirm the camshaft needs to be carefully slid out though the front of the motor, not lifted out like you would with say a CA18 or 3SGTE. Because of how the cam bearings are made removing them looks like it'd cause major problems.
2: In order to achieve the above you need remove the rocker arms,
-> Thus the question: in order to do this do you simply remove the spring clips, and wind out all the adjustment? Or do you need to compress the valve springs somehow? Eg: wedge a screwdriver underneath the cam and press on the spring? <-- Seems dodgy
Now here comes some tricky stuff: I've got a thoroughly unimpressive "C-Spec" Yo camshaft, which has an amazing 7.25mm of lobe lift.
As mentioned previously the new cam is a Works 72 Grind which has 8.46mm of lobe lift, but the thing here to remember is that all L-Series cams are effectively regrinds whereby lobe lift is increased by reducing the base circle, not by adding material to the lobe tip (I'm sure there's a good reason for this but I just can't think of it.) Therefore I've lost a minimum of 1.21mm from the base circle of the camshaft. Now as we're aware, these engines are sensitive to lash pad thickness so here comes the math:
Knowns
Rocker ratio: 1.5165
Reduction in base circle Radius: 1.21mm (min)
Head has been recently rebuilt and wear makes on wear pads are central:)
Unknowns
Lash pad thickness
Now if I multiply the radius difference by the rocker ratio I get: 1.8323mm (or 0.0721")
Would I be correct in getting a lash pad from the supplier (Precision Shims) that is 1.8323mm thicker than the existing lash pads (seems a lot?) or at least would this be a good starting point. Or better yet, can the Works 72 cam be installed and simply adjusted by using the screw adjusters with little consequence?
Thanks in advance for your replies. Also as I've looked everywhere for a step by step guide on how to do this and came up short (the workshop manuals are rather vague...) I'll be posing a how to once done.
Regards
Jordan.
