1600 - FJ20DET Won't fire up? http://ozdat.com.au/forum/viewtopic.php?t=32685 |
Author: | birdirt [ Thu May 08, 2014 2:08 pm ] |
Post subject: | 1600 - FJ20DET Won't fire up? |
G'day, I have a 1600 with an FJ20DET and it turns over, nearly fires up, but just won't start. The Microtech MT8 has a red light flashing slowly indicating a fault, any guesses as to what this could be please? Thanks, Grant. |
Author: | Nissanman [ Thu May 08, 2014 3:47 pm ] |
Post subject: | Re: 1600 - FJ20DET Won't fire up? |
Have you had a look on their web site? http://microtechefi.com/index.php?route ... ory&path=4 |
Author: | Anth510 [ Thu May 08, 2014 4:09 pm ] |
have you tested if the plugs are firing? is fuel making it's way to the injectors? |
Author: | birdirt [ Thu May 08, 2014 4:43 pm ] |
Yep, checkod out their website/manual, and the warning light is due to a sensor error. I read it could be due to a sensor not being connected such as a water temp or air temp sensor. Does the FJ20 have any sensors not available such as air temp? With regard to the fuel to the injectors, I pulled out a spark plug and it has a strong smell of unburnt fuel, so I guess it's getting in there. How do I check the injectors are getting fuel? thanks. |
Author: | xfacta [ Fri May 09, 2014 7:27 am ] |
Sounds like no spark then - the faulty sensor may be the crank angle sensor |
Author: | birdirt [ Fri May 09, 2014 9:07 am ] |
I checked one lead to a plug and it was sparking. Would a faulty crank angle sensor stop it from firing up? |
Author: | Anth510 [ Fri May 09, 2014 9:33 am ] |
I'm not sure about FJ's, but my daily driver Golf had a dodgy crank angle sensor and the thing used to stall at red lights and then fail to start again, so possibly. |
Author: | birdirt [ Fri May 09, 2014 12:01 pm ] |
Thanks for the replies. The low pressure fuel pump does not seem to operate either when the ignition is on, or when I disconnect the wires and hook it up directly to a 12V battery, no vibration, no noise or anything? Surely there would be some noticable response such as noise or vibration when connected? (There is a fuel filter after the high pressur pump which is still full of fuel after turning it over a bit?) |
Author: | birdirt [ Fri May 09, 2014 2:29 pm ] |
That low pressure pump seems to be buggered at any rate so I will replace it and see what happens. Would this Carter one do the job P4070 ? http://www.vpw.com.au/Category/Index/5726 Thanks. |
Author: | Nissanman [ Fri May 09, 2014 4:56 pm ] |
Pretty expensive for a low pressure pump. I think the one I used was a Carter. Cylindrical in line jobby. |
Author: | nick [ Fri May 09, 2014 11:04 pm ] |
You will probably still have a sensor fault. The ecu doesnt monitor the fuel pressure/pump afaik. If it hasnt worked for a while the pump might just be stuck like injectors do when they dry out. Give it a good clean with fresh fuel before you waste money on another pump... |
