Dat810 part 2 http://ozdat.com.au/forum/viewtopic.php?t=32608 |
Author: | Datto810 [ Tue Apr 15, 2014 2:22 pm ] |
Post subject: | Dat810 part 2 |
First this is my 200b story. I bought the car back in 2006, one owner all stock. And was my only car for a few years. It all started with a 32/36 weber, mags and new disks and pads. Move onto the clutch, bluebird diff, su carbys, 5 speed, cd player and a sports wheel. Then I changed my view chopped the springs got dark tint and started to strip some of the interior out. This go me defected and wasent such a bad thing. As It showed me that it was the wrong direction for the car. So I fixed the suspension put the inside back together gave it a tidy up and passed first go when I got the defect off. It was meant to be a weekend car after this but things changed and I only had enough room for 1 car and you can guess what it was. Next was the exhaust, 2" with luky mufflers. 40mm dellorto's, 4 wheel disks, ssr wheels and bigger sway bars. But while I was doing this, some rust started to come out I had some personal things going on. So I ended up doing a dummyspit with it put it down the back and moved on. The first 2 cars I got dident want this to happen and keep breaking so I would end up having to drive the datto again. This lead to me losing interest in cars for a bit. Untill I swapped my bmw (with a blown trans) for a micra. And dam this car was boring but relieable. Then one day the bug bit again. I was only going to fix a couple of bits and pieces on my micra then the next thing I had made it a very mild hot hatch. So I pulled the datsun out and have started fixing the rust with bog yer yer it's better than rust. I wasent to sure want my goal was I just had to do somthing. I was looking at selling it to help fund a new car. But it's probly only worth 2g and after having it so long and doing heaps to it I just cant. So because it's mechanicly a1 and not a bad set up but the body is now a bit ruff i'm going to fix/change some stuff join my local car club and use it for race/rally. |
Author: | Dato200B [ Wed Apr 16, 2014 12:20 pm ] |
Post subject: | Re: Dat810 part 2 |
Sounds similar to me. I always come back to the datsun. Although I a few others to distract me. Not sure how better bog is than rust but it looks better! |
Author: | Datto810 [ Wed Apr 16, 2014 2:02 pm ] |
Yer there's somthing about datsuns. It's actually fiberglass filler, but i'm not sure if thats any better. Just dont want it to rust anymore. I havent taken many pics just got into it. The first is a pic after i pulled it out and gave her a clean up. Attachment:
I started on the rear first poking at it to find out how much was there.Attachment:
From here i ground off any loose bit's, wire wheeled it, rust treated any bare metal, fibergalss filler, bog to smooth out bits, primer and finaly paint. It's not the right colour as i had no luck trying to paint a guard with the factory paint and by far not a professional job but better than it was.Attachment:
I have also done the rear quarters the same way. Got some good door's, rust treated the inside and am looking at new seals. Then it will be the bonnet as it has decent rust on the frame, so probly new bonnet time. Fit my autometer water temp/oil press/volt gauges and get some 14inch wheels with some cheap normal road tyres.Also going to go and watch a local rally meet see how it's run an find out if my cars needs anything else. |
Author: | Datto810 [ Wed Apr 16, 2014 2:46 pm ] |
And here's an update on the mods it has acquired over time. Series II bluebird L20B low k's, made 60kw/80hp at the wheels with a 32/36 weber and sss cam. Now running Twin 40mm Dellorto DHLA's, redline manifold, Cable acclerator, MSD coil, top gun 8mm leads, 2inch zaust Luky resonator in middle ultra flow in back. This massive power goes to a L24 flywheel/L24 Excedy HD clutch, the BB 5 speed, 1 piece shaft, BB H190 disk brake diff (Open or locked) and urathane bushes. Each corner has had new bearings, disks, performance pads, blue painted calipers, KYB Excel g shock, King spring low and an SSR XR4 Longchamp 15x6.5 +18 wrapped in falken 195/55 semi's. Selby 22mm front sway bar, factory BB 19mm rear, Steering box brace, Plus the normal new tie rod's, balljoint's etc etc. Also has extra stuff like Hella head lights, Aftermarket headlight cover's, first gen front bumper, Sunguard endurance tint 38% Front 20% rear, Saas Bathurst steering wheel, SX model factory tacho, early pulsar 5 speed gearknob, an Alpine cd player with Kicker 6inch spits, and stickers for the extra 5hp. Now some pic's Attachment:
When i first got the car.Attachment:
Just befor getting defected.Attachment:
After defect going for my first big test drive.Attachment:
Another weekend out in the datto.
Author: | Datto810 [ Wed Apr 16, 2014 2:49 pm ] |
And my engine evolution. L banger love. Attachment:
Author: | Datto810 [ Sat May 03, 2014 5:14 pm ] |
Picked up some toyota ae92 levin/trueno seats that are black and grey so sort off match the factory interior and are a bit better than the factory 200b bucket seats. Just sorting out the rails. Also fitted my aspen grill and cleaned/resealed the parkers. |
Author: | Datto810 [ Sun May 04, 2014 4:41 pm ] | ||
Post subject: | Re: Dat810 part 2 | ||
Seated.
Author: | Datto810 [ Wed Aug 06, 2014 1:54 pm ] |
Sold. |
