And here's an update on the mods it has acquired over time.
Series II bluebird L20B low k's, made 60kw/80hp at the wheels with a 32/36 weber and sss cam. Now running Twin 40mm Dellorto DHLA's, redline manifold, Cable acclerator, MSD coil, top gun 8mm leads, 2inch zaust Luky resonator in middle ultra flow in back. This massive power
goes to a L24 flywheel/L24 Excedy HD clutch, the BB 5 speed, 1 piece shaft, BB H190 disk brake diff (Open or locked) and urathane bushes.
Each corner has had new bearings, disks, performance pads, blue painted calipers, KYB Excel g shock, King spring low and an SSR XR4 Longchamp 15x6.5 +18 wrapped in falken 195/55 semi's. Selby 22mm front sway bar, factory BB 19mm rear, Steering box brace, Plus the normal new tie rod's, balljoint's etc etc.
Also has extra stuff like Hella head lights, Aftermarket headlight cover's, first gen front bumper, Sunguard endurance tint 38% Front 20% rear, Saas Bathurst steering wheel, SX model factory tacho, early pulsar 5 speed gearknob, an Alpine cd player with Kicker 6inch spits, and stickers for the extra 5hp.
Now some pic's
When i first got the car.
Just befor getting defected.
After defect going for my first big test drive.
Another weekend out in the datto.
